Question about Maytag MAV7600 Top Load Washer
Rinse and drain
My washing machine goes through all the cycles but doesnt rinse or drain the water . you have to run the rinse cycle four or five times just to get it to drain the water but it doesnt seem like it got all the soap out of the clothes
Just had this problem and fixed it by installing a new timer. Be sure to remember the order the wires were attached on the old timer.
Posted on Jan 05, 2008
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | GE WSXH208A Front Load Washer
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Maytag MAV7600 Top Load Washer Logo
138 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
