Question about Konica Minolta DiMAGE 7Hi Digital Camera
Dimage 7 hi no picture!!
Dimage 7 hi lcd and EVF is black when i replay my pics ty are black so i think lense is not connecting or something?
  • bonbof7 May 11, 2010
    can u see them on QV?
toto
  • 425 Answers
SOURCE: After upgrading the DiMAGE 7 to the Optional Enhancement software, when AF is confirmed on the DiMAGE 7 the live image on the LCD stops, is this a problem?
This is not a problem. In order to achieve faster AF operation, the live image on the LCD is not refreshed during focusing. During flex focus point, the live image on LCD never stops. If you feel anxious about the live image stoping, we recommend you to use flex focus point.
Posted on Sep 15, 2005
Arpi
  • 326 Answers
SOURCE: lcd blank but can hear picture being taken
Maybe the CCD imager is dead. Please contact your nearest Sony Service. If you need more info please advice
Posted on Mar 20, 2007
  • 4 Answers
SOURCE: EVF & LCD Black in shoot mode
I know this is an old post, but sounds like your CCD sensor is shot. Check out this link: http://dcviews.com/press/Konica-Minolta-Oct05.htm My camera did the same thing. It was 2years out of warranty, but Sony (now owns Konica-Minolta) asked me to send it in. When they could not fix it they gave me a brand new Sony Alpha DSLR-a100K!!!! Jid
Posted on Apr 09, 2007
pishta68
  • 593 Answers
SOURCE: lcd black, but can hear the picture being taken
As of last fall. 2008. Sony is done fixing these cameras under a recall. They still repair them but for a flat fee of 186.00.
Posted on Mar 13, 2009
  • 126 Answers
SOURCE: Lcd screen is black a the evf is black too. When
the ccd has went bad must be replaced . it will not focus with a bad ccd .
Posted on Apr 15, 2009
The led screen is black as is the video being recorded. Everything else seems to working. yes the lense cap is off. It as if no images are coming through the lense.
First, Please confirm that if LCD is blank then can you see the images in view finder ? If not then the CCD IMAGER is faulty and if LCD is blank and you can see the image in view finder then then a Flexible board which connect the LCD with the main unit is broken, Please replace these parts according to the symptom. Moreover, for your ease pics are shown below of both parts with part number.
First pic is for CCD IMAGER
second pic is for flexible board.
Thanks
Oct 22, 2010 | Sony Handycam DCR-TRV33 Mini DV Digital...
EVF is dead
It's a known issue with both the A1 and the A2, and is caused by very poor design of the strain relief to the flexible circuit board which eventually cracks. If you open the EVF you'll see a small piece of blue or yellow tape on the pcb just where the damage occurs: this was clearly Minolta's pathetic attempt to prevent the problem.
There is effectively no fix for this as the only way ro repair it is to replace the pcb and to keep costs down Minolta made the EVF flexi pcb an integral part of the entire pcb which snakes it's way deep into the camera. If only they'd redesigned it as a separate replaceable section then things would have been easier. You'll notice that Minolta omitted the tilting EVF from the successor to the A2, the closely related Dimage A200.
The best you can attempt to do is to peel off the rubber eyecup (it has a tendency to tear, so be very careful) and then remove the two screws from the underside of the EVF. You'll then see part of the EVF pcb. Note that there are actually two pcbs layered together, one does have a joint in it, but sadly it's not the one which has broken. You'll see a red and a black wire connecting to a plug which attaches to a socket mounted on a side spur of the broken pcb. The blue or yellow tape I mentioned earlier will be stuck to this spur (ignore the second piece of tape right near the EVF lens). Now set the selection switch to the EVF position and turn on the camera. By carefully and gently manipulating the broken area (the break is usually microscopic, so don't expect to see the damage) you can usually achieve a position where the EVF lights up. You may need to apply more tape or some folded paper packing beneath the pcb to get the EVF to remain illuminated, and usually will need to give it umpteen attempts so be patient. When it stays illuminated, reassemble and gently fold the EVF back down. You'll often find that you have to repeat the job a few more times as the action of moving the EVF back down upsets the "repair". Once it's down, and the fix appears to be stable (i.e. it doesn't black) out or blink every time you touch the camera) then carefully glue the eyecup back on and use your preferred method to stick the EVF in it's parked position. I use thin double-sided adhesive foam jointing tape: if you live near a modelling shop or know a radio control modeller, ask for a piece of thin servo tape.
The bad news is that this repair will not last and that you'll have to either learn to love the LCD panel or resign yourself to regular re-fixes, but eventually the damage progresses until beyond repair. For the same reason, if you replace it with a used example, go for the A200 instead. It has the same lens and many of the same features as the A2, although ditches many of the useful manual switches in favour of menu-driven settings.
If you are lucky enough to actually obtain a complete and unused flexible pcb then expect three things: 1. it will cost more than the camera is worth; 2. it will cost far more than that to have it fitted; 3. it WILL fail unless you stick the EVF down permanently as Minolta never revised the design. You probably won't find the part though as Minolta pretty well exhausted the spares supply whilst making repairs under warranty.
The same fault occurs to pretty much all cameras which have articulated displays, whether EVF or LCD and is why top-spec cameras aimed at professional users omit this feature. Pro's want reliability and give their gear a hard time, so articulated gadgetry is a liability.
It's a real shame as the A2 was otherwise my near-perfect all-rounder. In my case I only encountered the problem after buying a broken A2 for spares (just for the rubber eyecup and a few minor parts) and just a few weeks after investing in the rare, expensive and vital BP-200 battery grip. I've stopped using mine altogether now as I simply cannot get to grips with composing on an LCD panel.
Sorry this isn't all good news, but hopefully you'll find my posting to be of use and will be one of the lucky ones whose DIY fix lasts. Feel free to ask me for further advice and please don't forget to rate my answer.
Jan 29, 2010 | Konica Minolta DiMAGE A2 Digital Camera
I own a Dimage A2 and the viewfinder is very scratched. Can I buy one from anywhere?
In short, no. Spares are generally no longer available and expensive when they are.
But there are huge numbers of broken A1's and A2's which sell for near-nothing on auction websites which may be purchases as spares donors. The viewfinder lenses on both models are identical, although the actual electronic EVF display is different. Ask the right questions and buy wisely and you'll also end up with spare batteries and all the body covers which might have been lost from yours for no extra cost.
Jan 18, 2010 | Konica Minolta DiMAGE A2 Digital Camera
Cant view photos on the big screen of my camera
I think you must have pressed the EVF/LCD button which changes the review area to inside the tiny view finder.. the EVF/LCD button is found on the back of the camera at the top left hand corner.. it is a little silver button. Hope that helps.. :)
Jun 01, 2009 | Kodak EasyShare DX6490 Digital Camera
LCD screen not on when camera on?
You hit the EVF/LCD button near the "eye hole". When this is pressed it will cycle viewing through either the optical viewfinder or the LCD screen. This display is controlled independantly on each of the modes: shooting, or viewing. This is so you can set the camera to view pics before taking them from the optical viewfinder and view pics once taken from the LCD or vice-versa.
Nov 06, 2008 | Fuji FinePix S700 Digital Camera
What is the frame rate of LCD display?
Both EVF and LCD displays at 60fps for still image recording and 30fps for movie recording.
Sep 15, 2005 | Konica Minolta DiMAGE A200 Digital Camera
What is the number of pixels of the EVF?
The ferroelectric 4.8mm (0.19 type) reflective micro LCD adopted for DiMAGE 7i's EVF has approximately 220,000 pixels.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Sep 13, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Konica Minolta DiMAGE 7Hi Digital Camera Logo
18 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
