Question about Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
It won't type without pauses - Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000
  • 59 Answers
Replace the batteries, if problem still exists then move the wireless receiver to a closer location.
Posted on Sep 24, 2009
When I send a print job to my Z4MPlus label printer, the label prints but without any ink on it. It is set to Direct-Thermal. What else should I be looing for to correct this issue?
Hi, you can have 3 scenarios here, the print head is faulty, mainboard faulty or darkness set to low, please reset printer to factory default without any lpt/com/usb/network cables connected, turn off and on. try to run Pause test ( turn on printer with pause button pressed for 5 sec and release it)
Feb 21, 2015 | Zebra Z4Mplus Label Printer
Tip
How to check for IEMI number?
<span> The International Mobile Equipment Identity is a unique identifier of your phone from the rest of the users. It's usually located on the battery compartment of your phone. But for quick retrieval you can follow this simple steps that is accessible by typing in a code: <br /> On the main menu(the portion where you can manually type-in numbers) type this characters in a quick manner without pausing: *#06# <br /> However, for Motorola Iden this is the code: <br /> Again, in a fast manner without pausing # - *- [Menu], then right arrow</span>
on Feb 01, 2011 | Cell Phones
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
I pushed the 'pause' button during the wash cycle of my LG WD-3274HD and now the door won't open.
Hi!
The machine knows it dint't finish the washing cycle, and, because it may be possible that water is still a lot inside, the door is locked.
If you are shure the door can be opened without the water coming out by the door, simply disconnect it from the electrical supply and wait a few minutes until the door unlocks. (you will hear the unlock click)
Aug 08, 2011 | LG WD-3274RHD Front Load Washer / Dryer
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Want to unlock my lgV692WK dvd vhs combo player
1. Turn on dvd without disk
2. Press pause
3. Type 314159 wait for menu to apper
4. Press 0
5. press pause
6. Turn off for 10 sec then back on
7. Regionfree!!
Jay
May 10, 2009 | Televison & Video
I can't find a way to pause my DV-DV1-VP vamcorder
The Paly/Pause button can be pressed while recording. It is located in the center of the buttons found on the bottom edge flip-out LCD display
Hope this helps :)
Jan 08, 2008 | VuPoint DV-DV1-VP Camcorder
XBox360
I don't think you'll have any problems with burn in on a rear projection TV. CRT and LCoS type televisions can have burn in problems
Dec 10, 2007 | RCA D52W19 52" Rear Projection Television
Logitech Cordless iTouch Keyboard/Cordless Optical Mouse 967204-0000 Logo
53 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
