Make sure that the output from the diecttv reciever is not on a format that your telivision cannot handle. It is usually because the reciever is set for 1080p and your tv can only process 1080i(i=interlaced & p=progressive scan). Verify that this is not happening. Also try a different HDMI cable. The one that you are using might be bad.
It sounds like the resolution is set too high. try turning it down to something lower on both units and see how that works. also, the sound format might be in the wrong format as well. both of these options can be configured in their respective "system settings".
