Question about Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator
Newly installed filter but black gunk floating in water from dispenser. I can't turn the filter cap to see if it's inserted correctly
  • 432 Answers
I have done that before. Ask someone thats stronger than you to help you.Tell them how to take it off. Its not on correctly.The black is the O-Ring seal thats deteriorated.See if you can get a new one and put a (little) petrolium jelly on it .
Posted on Sep 24, 2009
Testimonial: "Thank you! This was such a big help."
  • 999 Answers
The filter has carbon in it and was supposed to be rinsed out till clear. You will have to remove it and rinse it some more. If the cap will not turn it is either over tightened or cross-threaded.
Eric
Posted on Sep 25, 2009
Sometimes my fridge dispenses water with brownish gunk floating in it. I've changed the filter which doesn't make a difference. What could it be and how would I get rid of it?
Inside the refrigerator side there is a coil of plastic tubing that holds enough water for a glass of water . This tubing runs from the inlet solenoid up into the refrigerator, through the filter, out the front behind the grille and over to the freezer door hinge then up to the dispenser spout. That hose, after a while will cause that gunk to appear. It's not a do it yourself-er job to replace that hose, so get a quote from a repair shop . If the refrigerator has a lot of age on it, the cost of parts and labor may or not be worth it.
Nov 15, 2015 | Refrigerators
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Nov 06, 2015 | Refrigerators
How and where do you change water filter
From the KitchenAid Manual:
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Replacing the Water Filter
To purchase a replacement water filter, model 67003523 Part
Number 4396395, contact your dealer or call 1-800-442-9991
U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. Depending on your model, see
"Water Dispenser" or "Water and Ice Dispensers."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
http://www.kitchenaid.com/digitalassets/KFCS22EVMS/Use%20and%20Care_EN.pdf
May 16, 2014 | KitchenAid KFCS22EVMS French Door Bottom...
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
How to change the water filter on my Kitchenaid Superba fridge?
The details are on page 6 of this manual or I have pasted them below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202306982.pdf
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the protective covers from the O-rings.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See “Water and Ice Dispensers.”
Apr 16, 2010 | KitchenAid Superba Architect KSCS25INSS...
Soap stays in disperser. Water is 142 degrees, dispenser opens.Not overloaded and filter under bottom wand is clean. Model is 16342
Either:
  1. check if the bottom rack is inserted correctly. Try turning it 180 degrees and run the cycle. Make sure nothing obstructs the dispenser.
  2. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  3. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  4. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Feb 16, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
How do I take out the water filter?
Found at Kitchen Aid website, Good luck
1.
Jun 30, 2009 | KitchenAid Superba KSCS23IN Side by Side...
Kenmore side by side dirty water
the problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The original cap for the filter, was supposed to be a plug bypass, for application of outside undersink filter. Using, this, one can check to see if the filter was the contaminant here. You need to be, more specific, to explain a problem. Something is too too generasl,,, color, consistancy, odor, quantity, filter has a fine fine filtrationl unit on the outlet, and if defective the charcoal residue may come out. You can remove filer and pass suppy water thru and review the effluent coming out. ??? Regards, fmauka
Sep 19, 2007 | Kenmore 53642 / 53644 Side by Side...
Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
