Question about Brother MFC 1850MC Thermal Printer
New cartridge installed but will not print
I have installed a new cartridge but the fax unit will not print. I have tried to make copies and recieve faxes but only get blank pages. There have been no error codes that I know of and there are none now on the display.
  • dalewhttn Dec 16, 2007
    may be the appropriate info but not sure how to do a self test.
    Don't have a manual for this unit.
  • culnanca Oct 23, 2008
    Installed a new cartridge but can't print (copy or receive). Cleaned as directed (machine was already really clean). Perplexed...
    Champion:
  • 238 Answers
Hi, first take a printer self test to check if the cartridge is installed properly,as sometimes we forget to remove the protection tape on the nozzel of the new cartridge.. let me know
Posted on Dec 16, 2007
2 Suggested Answers
Khalsa007
  • 79 Answers
SOURCE: I can print but can't copy or recieve faxes
you can try the following steps .
Take out the cartridges from the unit .
Make sure the unit is connected to the wall jack directly without any surge protector.
Unplug the power cord from the back of the unit ( without turning off the unit ) .
Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5
Do not release the keys after a few seconds u will find te hp logo or bars moving across the screen .wait while the unit turns off.
6
after one minute turn on the prnter . it will go into alligment phase > let it finish .
7
after its done > try to make a copy .
Note - you can also try the Ok n cancel key combination in place of # and 6 .
Thanks
Posted on May 27, 2008
WILL NOT PRINT FROM MEMORY
I cannot recieve a fax from memory, I have refilled B cartridge, Window display recomends new cartridge, I can make a copy in copy mode, this tells me cartridge is OK. my machine is a Canon
MX310
Jul 12, 2010 | Canon PIXMA MX310 All-In-One Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
Had toner life end message. Replaced toner and drum with oem,machine reset but now just making blank copies. Tried to print internal report that's blank too
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Aug 01, 2009 | Brother IntelliFax-2820 Laser Fax
Prints only right 1/3 of page with new cartridge.
remove the cartridge and install it again
try to remove and putt back for three times if this not help return the cartridge from where you had both it
Jul 11, 2009 | Brother IntelliFAX 560 Plain Paper Fax
My hp printer fax does print when recieving a fax but doew print normally when coming off computer. Fax machine sya low on ink should I check both cartridges and get new ones
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Jul 10, 2009 | HP 920 Plain Paper Fax
Hp 3015 prints light with new oem cartridge
Machine may be in econo mode. To enable/disable.
Hope this helps
  1. open the Printer Properties (or Printing Preferences in Windows 2000 and Windows XP).
  2. On the Paper/Quality tab or the Finishing tab deselect EconoMode check box.
Apr 01, 2009 | HP LaserJet 3015 All-In-One Printer
New cartridge; now won't print any document, fax or copy
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Oct 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
5
6
7
Thanks
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Brother MFC 1850MC Thermal Printer Logo
74 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
