Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Top load 10+ yr whirlpool washer will not spin
  • 15,935 Answers
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
WASHER MOD.#LSQ9549LWO NOT SPINNING CLOTHS COMPLETELY DRY,ESPECIALLY LARGER LOADS
sounds like your clutch could be slipping not giving you full speed spin, i've heard you can install a #10 washer into the clutch spring cap and it would work fine , keeping you from replacing the clutch!
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our LSR7233HQ0 washer is 10 yrs. old and the agitator stopped spinning. Any repair tips?
You may have broken the drive belt. Can you hear the motor spinning still? If yes, then it is definitely a broken drive belt.
Oct 25, 2009 | Whirlpool LSR5132PQ Top Load Washer
Leaky Maytag
most likely. the tub seal is bad. mine did the same thing. had to replace the seal. part is called a triple lip seal. not hard but not a walk in the park either.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Shuts off in between rinse and spin cycle
check the lid switch. if it's loose, worn or broken washer won't drain/spin. try pushing down on the lid when it's stopped. switch is either on the right side visible with a small hole that a plastic activator on the lid itself or on some activated by the left hand rear hinge under the top and need the hinge tightened only..
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
