Question about Cameras
Panasonic nvgs120 digital camcorder will not eject tape...when eject button is pressed the machine makes the few mechanical noises usually associated with the tape being ejected but nothing happens
  • 3,741 Answers
First of all check out is the battery old or new. if its old then this problems happens. so replace the battery. but if the battery is new. then check out is it properly charged or not. if not charged then this problem happens. charge the battery properly and then try.if the battery is new and also properly charged still the same problem then. remove the battery from the camera. wait for 2 minutes. then press the ON button and then insert the battery and then check out.if still the same problem then.keep the camera ON and then press the eject button randomly 10 to 15 times non-stop.then check out.if still the same problem then. keep the camera ON and pat the sides of the camera with your hand on its sides. also hold the camera tightly and wiggle/shake it then try to eject the tape.if still the same problem. then it’s the problem of internal gear assembly inside the unit. the gears which moves the tape IN/OUT are worn out and due to this when you press the eject button some noise comes but the gears are completely worn out so its not ejecting the tape. if the gears are worn out then the gear assembly can be replaced by a local electronics repair center who deals in camera repairing.the cost can be near to $15 for gears assembly plus the service charge of the store mechanic. in many cases it has been noticed that due to some dust/rust the door tray which ejects the tape gets jammed/blocked so inserting a thin knife in the sides of the door tray and pressing the eject button releases the tape also trying to pull the tray back slightly helps in removing the tape. but if the door tray is hardly jammed then don’t force as it can crack/break the camera components internally and lead to major damage inside.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Posted on Sep 24, 2009
Sony handycam ccd-trv59e C32 10
The camera's firmware has sensed a jam or too slow rotation in the cassette's take-up roller. Really difficult to overcome. The tape may already be snarled round a roller, but is certainly in the "loaded" tape path. I've had this and had to disassemble the whole tape transport mechanism - which is really difficult - after trying unsuccessfully to drive the unload motor from an external 6v power supply. Sometimes a really hard sideways bang on the camera can free up the roller enough to let it rotate a bit, satisfy the motion sensor and allow an eject.
Jul 07, 2014 | Sony Handycam DCR-TRV520 Digital Camcorder
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
Panasonic NV-DS65 won't eject a tape
It sounds that what's happened is your idler wheel is slipping or even your main drive belt.
When you loaded the tape it was taken by tape guides around the video drum. When you pressed eject the tape guides returned to their proper places but the tape stayedin a loop around the mechanism because the take up spool had no drive to pull the tape back into the cassette. When you've tried to pull the cassette out of the camera that loop of tape has snagged on part of the mechanism and that's what is stopping the cassette from being removed. I'm afraid the tape would be damaged at that spot so you may as well simply snip it with a pair of long bladed scissors and the cassette will pull straight out.
What is then required is either the drive belt changed or the idler wheel assembly changed. Either way a service center will be required unless yourself or a friend is able to buy the parts (not expensive) and do the work required.
Good luck
Apr 24, 2010 | Panasonic NV-DS65 Mini DV Digital...
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
CAN NOT EJECT TAPE IN PANASONIC PV GS85
you can try to pres the reset button and that my work.
Nov 03, 2008 | Panasonic PV-GS85 Mini DV Digital...
Canon ZR70 MC Mini Digital Video Camcorder...Not ejecting
Typically, the problems of this sort tend to be one of a mechanical nature; In other words, the case may be bent, causing this problem. Does the machine make a "motor noise" as the well opens? And then makes a "binding noise" before coming to rest? This would be a definite cause for your dillema, and a camera shop visit would be in order, unless you have some mechanical aptitude....accordiaman
Jul 02, 2008 | Canon ZR200 Mini DV Digital Camcorder
Panasonic PV-GS150 wont eject
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 17, 2007 | Panasonic PV-GS150 Mini DV Digital...
Tape holder jammed
remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Jul 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Panasonic DV-Camcorder tape problems.
i used to service quite a few older camcorders, many of them had some sort of rubber band pulley mechanism and the band itself would go limp (corroded) and not providing enough torsion to drive the mechanics of the camcorder
(imagine a slipping fan belt).
you'll have a real hard time getting an exact replacement, and at great expense.... i've had success splicing a normal rubber band, simply razor cut the ends to meet and use the tiniest dot of superglue to make a band of your length... an untreated rubber band would maybe last about a year unless you wipe it with a coating of silicone which extends it's useful life by 10 times (i have a diy treated rubber band in an older cassette deck still running strong after 12 years)...
good luck with the fix.
Jan 01, 2018 | Panasonic PV-DV702 Mini DV Digital...
Tape jam
First try to press the power button and the eject button at the same time. If that dosent work its advised to take it to a repair person as taking apart a unit like this can cause more problems then you have now. Lets just hope that its not to late and that the camcorder dosent have those pana caps that always goes bad. Good Luck
Jun 10, 2006 | Panasonic NV-GS11EN PAL SYSEM CAMCORDER...
Cameras Logo
19 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
