Question about Canon ImageClass D861 Printer
I need new rollers for my canon imageclass d861 for the top paper feed where should I go to get them?
  • Canon Master
  • 4,338 Answers
Find them on this site, or call their toll free number.
http://www.precisionroller.com/paper-feed-components-for-canon-imagerunner-2010f/products.html
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Sep 24, 2009
Canon Imageclass D861 Has lines going from side to side does not do it all the time but once it starts gets more lines sometimes fills the whole page up. Only does it on printing from the computer don
There is a clean function on this machine that cleans the rollers. Go to additional function section on menu. Then use arrow keys to go to adjust/clean.Then press set and then use arrows to go to roller cleaning. Then press set again.
Mar 26, 2014 | Canon ImageClass D861 Printer
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Hi I have a paper jam at the fuser rollers on a Canon ImageClass D861. I can't figure out how to get at it. Can you help?
You accually need a new fuser unit and to take it out its quite a mission.
you need to remove in this order:
the drum unit
the left panel holding the glass
the glass
where the scanner is there is a black thin guide holding the ribbon cable...take that off.
the display panel
bottom left side panel
bottom read side panel
bottom top panel
flip over the black milar cover over the power supply.
disconect the 3 cables
move the platern about half way and you will see the holes on top of the platen aligned to the bottom so to get to the 3 screws holding the fuser unit.
undo the screws with a long star screw driver and slowly wigle the fuser out.
to put it back you do everything in the opposite order.
Good luck
Oct 02, 2009 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D861 Need Vista 64 bit drivers
I don't think Vista is supported for this printer and if not doubt that it will be as Microsoft are bringing out a new OS to replace it.
Jul 28, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Adf
this is a dealer only item, if it's not pulling paper and you can see the feed roller turning,you may just need new feed rollers,but you would still need to order those from you local canon dealer
Sep 18, 2008 | Canon ImageClass D880 Copier
Paper jam
Your best bet is to have a canon tech check this problem out. There are several causes for this issue; a bad delivery roller, a small piece of paper lodged out of sight. Canon help is 800 ok canon.
Jul 09, 2008 | Canon ImageClass D861 Printer
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Canon ImageClass D861 Printer Logo
144 people viewed this question
old marine
old marine
