Question about Craftsman 25cc Gas Line Trimmer
What would be the standard settings for a walboro carb low and high speed screw settings
2 Suggested Answers
  • 36 Answers
SOURCE: Craftsman 25cc weedwacker (358.791030). Zama
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Posted on Sep 22, 2010
Adjusting the tickover and mixture
The carb is factory set you need to remove carb you will then see two screws one marked L and the other H with a small hacksaw cut a slot across both screws don't worry about cutting into carb body this can't be helped screw both screws fully in then back them off 1 and 1/4 turns this rough sets high and low running start saw set low speed first adjust screw in or out to get best low running then rev saw to max.and adjust max revs do the same as you did with the low speed screw to obtain max revs this should solve your problem.
Mar 07, 2015 | Ryobi Garden
How do i set the carb on a ryobi
I haven't heard of Ryobi using a carb different to most similar machines which use a small diaphragm-type carb which uses suction impulses from the 2-stroke engine crankcase to lift fuel from the fuel tank into the carb. There is generally one screw which is a throttle stop and two screws which are fuel volume screws; one with a greater influence at low speed and idle and one with greater influence at high speed. The low speed screw does have some influence at high speed and the high speed screw does have some influence over low speed fuel mixture.
The basic settings of the screws should not be lost and if stripping and cleaning the carb each screw should before removing be carefully turned in, counting the turns, until it bottoms so after cleaning it can be returned to its former position.
The amount of adjustment from the position the manufacturer set each screw to would typically be in the order of plus or minus one-eighth of a turn and if adjustment of more than about a quarter-turn is needed it could indicate the carb needs a thorough clean.
Making an adjustment of one screw means adjustment of the other is almost inevitable. The basic requirement is for the machine to work under load efficiently at high speed and it is usually desirable the machine will be capable of idling. Obtaining both is rather a balancing act and will need some patience and time making minor adjustments of each screw and in practice some compromises must be made and if hard work at speed has been achieved it usually doesn't pay to try too hard to achieve a smooth idle.
Feb 25, 2015 | Ryobi Garden
Husqvarna 445 starts and stops running
check carb settings. turn low speed adjusting screw all the way in then turn it out about 1 1/4 turns out. repeat with high speed screw. when running readjust low speed until proper idle and high speed for proper high rpm .
Nov 24, 2013 | Garden
Homelite mighty lite 26ss - Carb needs adjustment. Which screw is which? What are the initial low and high screw adjustment settings? Thanks
Starting with the question which screw is which: the low speed screw is closest to the engine and that makes the high speed screw farther away. Set the screws 1 turn out and then adjust as needed.
Feb 14, 2011 | Garden
On small 1985 14 inch craftsman chansaw what is the high and low settings set on the carb
Not knowing the model, you can always look on the body of the carburetor, there should be an "H" for the high speed mixture screw and an "L" for the low speed or idle mixture screw. Both screws should be set initially 1 to 1 1/2 turns out from seat and then the carb. will have to be fine tuned from there. The high speed screw is adjusted when the throttle is in fast position, at 1 1/2 turns out you should have a slightly rich mixture so you may need to slowly turn it in until you hear the saw's rpms start to increase. You want to find a medium point between too rich and too lean. The low speed or idle mixture screw is set the same way just at idle rpm instead of full throttle, find a medium between too rich and too lean. You should be able to throttle form idle to wide open without any "lag" or "stumbling". You can also offset any rpm change at idle with the idle speed screw (not to be confused with the idle mixture screw). Hope this helps.
Feb 13, 2011 | Garden
I have a Toro 524 with Tecumseh engine, model 38040 8 0000640. I am rebuilding the carb and would like to know what are basic settings for idle and hi/low speed screws?
The high speed mixture screw is initially set at 1 & 1/2 turns out. Then adjust it to give good acceleration and top speed, while not closing the screw more than you need to. The low speed mixture screw is set at 3/4 of a turn out. Adjust that, to give a smooth idle. The 3rd screw, the idle speed screw, is set to give a low idle speed without stalling.
Jan 14, 2011 | Toro Blowers Rake and Vac - Electric...
I have an echo srm2501. could you tell me the standard settings for the low speed trottle screw and the high speed screw
On these little carbs, a good starting point (before fine tuning the carb) is about One and one-half turns out (counterclockwise) from a lightly seated postition. That should allow the unit to start and you can fine tune from there.
Aug 21, 2010 | Garden
LOW and HIGH speed screw settings
you those to adjust the carb hi is balls out running , sometimes it sounds sick or spudders when cutting the hi will clean that up small turns only . low is for idle. ok
Feb 22, 2010 | Garden
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Craftsman 25cc Gas Line Trimmer Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
