Dyson Ball DC24 Bagless Upright Vacuum Logo
Posted on Sep 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The hand-held wand wont slide back into the tube. It wont go down far enough to click in and become the handle again. It was working fine but all of the sudden won't fit back in.
Anonymous
Level 2:
Scholar:
  • Expert 78 Answers
  • Posted on Sep 24, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
78
Questions
0
Helped
23388
Points
243
Sounds like the tube has something inside of it that is obstructing the path. veriffy the the "female" end of the tube isnt obstructed, and also, make sure that nothing is bent ( which can happen easily). use a flashlight to shine down into the tubes and check everything out. you shouldnt need to use a lot of pressure when trying to make the tubes fit. if it doesnt fit, dont force it, basically.....try turning the tube too, and that should work.
How to put the telescoping wand back and use DC25 vacuum again as regular?
Carefully put metal tube back into the hose so that the hose is on the outside of the tube Make sure that it is the correct way around when fully returned i.e. that the handle part is the right way.
Dyson wand, handle and hose are all unattached. How do I put them back together?
You can find a copy of the DC14 Manual here (
https://www.dyson.com/medialibrary/Files/Dyson/Support/downloads/US/Floorcare/manuals/dc14_opmanual_usa2007%20pdf.pdf ) Pages 4, 5, and 6 have plenty of schematics for putting the wand/handle assembly back together and getting everything to click. In a nutshell, the metal tube pretty much just slides back into the tube top, and then the slid-in tube clicks back into the top of the machine.
Good Luck!
I have a Dyson Animal vacuum. My wife removed the handle to use some of the attachments for cleaning. When placing the handle back to the vacuum, she attached the top part of the handle back to the...
Sorry to hear you're having difficulties with your DC07 Animal. From what you've described, it sounds as if the wand has been replaced on the cleaner without the hose being retracted. To remove the wand from the machine, hold the cleaner securely in place by placing one foot on the cleaner head, then pull the wand up forcefully whilst holding the purple quick-draw hose release (located above the on/off switch) down. Make sure you are not leaning over the top of the wand as you do this.
Once you've freed the wand from the cleaner, make sure you retract the wand before replacing it on the cleaner again. Hold down the hose release button on the hose cuff as you retract the wand inside the hose.
You might find it useful to refer to the user guide supplied with the cleaner - in case you don't have this to hand, you can download a copy here:
http://media.dyson.com/downloads/us/floorcare/manuals/dc07_opmanual_usa.pdf
If you have any further queries about using or maintaining your Dyson cleaner, please call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need. Alternatively, you can resolve many issues without picking up the phone by visiting www.dyson.com and clicking 'Support'.
Kind regards,
Jack
Dyson Online Customer Support
I disassembled the handle to attempt to remover the slip in upper half of handle. (did not figure out how to do tht). Now on re-assembling the handle, I cannot figure how the trigger is held secure to...
HI.These are the steps that may be helpful since you haven't describe the brand of your unit.Open the storage door at the front of the vacuum.Redmove the powered hand tool. Set it aside.Unsnap and remov any attachmets at the attachment storage area.Unclip and remove the wands from the vacuum and set aside.Pull the end of the hose from the hosed tube rack.Twist the other end of the hose from the dirt duck tube.Remove the hose.Unscrew the back of the handle.If you can't remove ,it is held tightly with nbuts located at the back of the compartment bag.Pull the handle carefully from the vacuum.If it has a non built cord wrap,slidethe wrap straight up from the handle too detach it before removing the handle.Once done assemble back.Thank you for choosing fiXYA.
Jul 31, 2011 • Vacuums
3helpful
Replace accessory hose
i There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
7helpful
2answers
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
The wand is hard to pull up
The wand on this machine get lots of tiny dirt and fine dust caught in the sliding tube that fits in the hose. You will need to take the hose at its cuff end where it meets the wand and press the two tabs to release the wand out, then take some spay cleaner of any kind and wipe down the wand tube. This should make it easy to slide in and out of the hose. Now just put it back together.
1helpful
Vacuum wand won't retract fully into it's compartment.
HI,
FIRSTLY DETACH WAND FROM UNIT AND SLIDE HOSE DOWN AS FAR AS IT GOES, SPRAY A LITTLE WD40 OVER WAND AND SLIDE HOSE UP AND DOWN, AS FOR THE CAP, TAKE A PAIR OF PLIARS, GRAB HOLD OF END OF CAP AND PULL CAP FULLY OUT OF THE HANDLE,AT THIS POINT CHECK THE SPRING OR REMOVE THE SPRING IF YOU PREFER AND PUSH THE CAP BACK INTO HANDLE AND THAT WILL DO IT FOR YOU.
REGARDS
DAZ
3helpful
Wand
Do you have a telescopic/height adjustable wand or just two tubes which have to be stuck together? If they are made of plastic well, it may well be broken. If its metal check that the tops aren't corroded or the handle itself isn't broken. If the tubes/wand isn't sliding up and down (i.e. if its height adjustable) then something has got stuck. Sadly for this kind of repair you'd be better off to buy replacement wands or consider something aftermarket on EBAY. Check the diameter of the tubes with a ruler. If it is 3.2cm (32mm) or 3.5cm (35mm) you can buy replacement tubes. If you can't afford that then try furniture polish on a J cloth or similar and with a stick wedge it inside the tube/wand so that it adds a little lubrication or simply a clog - it sounds like there is dirt clogged in the part that slides. Dont forget to rate, thanks.
Jul 26, 2008 • Vacuums
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
