Question about Kenmore Sewing Machines
Model # 385 12116690 kenmore sewing machine. The
Model # 385 12116690 kenmore sewing machine. The knobby feet that push the fabric thru are not pushing the fabric. When I open the door and look inside, I can see them moving up and down, but they're not moving the fabric as I sew. Please let this be an easy fix!
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
SOURCE: reverse on kenmore sewing machine 385
I recommend that the machine be serviced by a professional but if you're handy it may simply need cleaning around the reverse cam. To do this place the machine on it's back. You'll need to access the rod that drives the feed dogs and cam mechanism by removing all screws holding the bottom plate of the machine. Remove the bottom plate. Note that when you push the reverse button, while turning the wheel a thin rod moves left which allows a plastic cam mounted to the cam rod to also move left and engages the feed dogs in reverse. If the cam is not moving enough or if too slow, it may be that the rod and cam need cleaning and lubrication. Clean out all lint and lubricate the cam where it moves on the shaft. Try to get it to move more freely without forcing it. When done replace the bottom plate. I just repaired my wifes machine and this solved the problem. Hope it helps.
Posted on Feb 17, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
SewTechWayne
  • 186 Answers
SOURCE: Kenmore Sewing Machine Model #158.18032
You probably have a bind in the feed dog mechanism. If you can remove the covers and manually force them down you will see the hinge points that need to be oiled.
Unplug first!
Good luck.
Posted on Jan 30, 2009
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
NEED DIAGRAM FOR THREADING A KENMORE 158.19802 SEWING MACHINE
The threading on these Kenmores is pretty consistent from model to model (good machine, by the way!). Be sure to ALWAYS raise the presser foot when threading the upper thread--insures the thread seats in the tension disk.
14 Kenmore Top Threading FREE SAMPLE
How to thread Sears Kenmore Sewing Machine 158 12270 158
By the way, the metal projection at the top left of the machine regulates the amount of pressure the presser foot applies to the fabric and feed dogs. Push it down to increase the pressure--important when changing types & weights of fabric. To release the pressure, push down on the ring that surrounds the center projection piece. AND, when finished sewing, it is a "great" idea to always release this pressure button before walking away from the machine. Leaving it pushed down over a long period of time will eventually compress the spring and the pressure will no longer work like it should. Also, be sure to clean and oil your older Kenmore regularly. Use only fresh, good quality sewing machine oil or liquid Tri-Flow Synthetic Lube. Open the top, side, and bobbin area. Gently rotate or rock the handwheel and apply only 1-2 drops of oil every place metal rubs against metal. You can also lube the specific lever and dial mechanisms to keep them operating freely. Do NOT oil belts or plastic gears/parts. Doing this regularly, ie every 40-60 hours of sewing time, will keep your machine running smoothly and quietly and preserve the motor from over stress and possible burn-out.
Dec 31, 2016 | Kenmore Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
http://makeitsew.biz/presser-foot-pressure
Sewing Machine Pressure Settings for Machine Quilting
Dec 20, 2016 | Kenmore Sewing Machines
How to lower the feed dogs for free motion sewing on model # 16782
There are most likely some numbers missing from the model number you provided. Usually, there is a 3-digit beginning number, ie 115, 385, 401...
I am unable to find model information based on your number, but you can most likely get a user's manual through Sears or try searching the internet (Make Model manual), ie:
Kenmore Sewing Machine Manuals Instruction and Repair Manuals
Sewing machines generally have two ways to disable feed dogs. One way is a lever or knob on the machine itself that physically "drops" the feed dogs so they are below the needleplate. The feed dogs will continue to operate but since they are below the sewing surface, they will not have an effect on the fabric movement. The other way is an accessory that attaches to the needleplate which covers the feed dogs and creates a flat sewing surface.
Another item that is important for free motion quilting is a darning foot or free motion foot. These presser feet are physically shorter in height than a standard presser foot. This means the darning foot, when lowered, does not apply "pressure" to the fabric when it is lowered. It, instead, provides leeway between the presser foot and the fabric so there is room to manually maneuver the fabric while stitching.
You'll just need to CONFIRM that the presser foot shank is correct for your machine (low shank, high shank, slant shank).
There are probably a multitude of designs available for your machine, either Kenmore or generic brands. Once you've determined your machine's shank, it would be a personal decision as to the design you'd prefer, which could be metal or plastic, closed, open, or clear see-thru as well as various shapes, round, oval, etc. There are also some feet that are spring-loaded so they "hop" while you stitch, or feet that are solid.
These are examples of different darning/free motion presser feet.
Darning Foot Low Shank 4021
Nancy Notions Trusted by sewing enthusiasts for more than 3 decades
Amazon com Tinksky Sewing Machine Open Toe Metal Quilting Embroidery...
Free motion Darning Quilting Sewing Machine Presser Foot Fits All Low...
Nov 27, 2016 | Kenmore Sewing Machines
I have a Kenmore model 158.19411 and I want a walking foot for this model. Is this model a high shank or low shank?
The Kenmore 158.19411 uses super high shank presser feet. Sears Parts Direct has the zipper foot still available for the 158.19411. http://www.searspartsdirect.com/kenmore-sewing-machine-parts/6759/0020/158/model-15819411/0582/1220000.html . Other compatible feet are available here: http://www.sewingpartsonline.com/kenmore-158-18023-sewing-machine-parts.aspx . This site also has an adapter for connecting Kenmore-compatible low shank presser feet to the Kenmore 158.19411 .
I hope this helps.
Aug 23, 2015 | Kenmore Sewing Machines
How can I find accessories for an old machine?
Sewing shops are loaded with this stuff. You can order online too. You'll need the make & model number. Do a little research, I think Kenmores are simply repackaged Singers.
Aug 05, 2015 | Kenmore Sewing Machines
The feet will not move the fabric.????
sorry but perhaps a trip to a sewing machine repair man is needed .
Aug 05, 2015 | Sewing Machines
Presser foot does not hold fabric tight to the feet underneath.
Normally the white machines have a pressure button on the top left end of the machine that should be pushed down. Newer models may have a dial in the same area with numbers, turn it to a larger number.
Jun 02, 2010 | White Sewing Sewing Machines
Can I buy a zipper foot attachmet for the Kenmore model 1703 sewing machine?
You can find generic presser feet at fabric stores. Hancock has a great variety - JoAnn, not so many.
Take a presser foot with you when shopping so you are sure to get the right shank - the newer machines have low shanks and the old ones long shanks.
Feb 20, 2010 | Sewing Machines
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Sewing Machines Logo
421 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
