Question about Duravit 111335001 Geberit In Wall Carrier for Wall Mounted Toilet
GE LW-11-P wall mounted refrigerator
Recently purchsed a house with a wall mounted GE fridge Model LW-11-P that is not working properly. Any help/suggestions will be appreciated.
GE LW-11-Pfrom 1955 .I need to found location of filter, to replace a compressor
You are expressly forbidden to work on refrigeration equipment unless you are registered. You have to collect refrigerant gas and not allow it into the atmosphere. For that you need a vacuum pump and collection cylinder. Then you need Nitrogen to fill the system after repair and then test it for leaks. Then you let the nitrogen out, apply a vacuum and let the R121a into it.
If your unit is from 1955, the gas used then is banned. If you are a refrigeration engineer, you would know what a filter canister looks like. If you really like your antique fridge, you would give it to a refrigeration company and have them put a completely new compressor and control system in it, just leaving the evaporator (the bit that gets cold).
Jul 20, 2017 | GE Refrigerators
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My GE fridge, isn't defrosting properly. I am getting condensation build up in my freezer and fridge side. I have the model number GSC23KSTASS.
keep the fridge in such a position that all three side of the fride is open to air and only back portion towards the wall and also note to keep some distance between the wall and fridge
Dec 13, 2010 | GE Refrigerators
GE side by side keeps frosting up and fridge is not very cold
It sounds like you have a defrost system problem. most commonly its your defrost heater on most GE ref. It can be located by removing the back panel of the freezer. If you remove the heater it can be tested for continuity at any parts distributor. I would also look for the quarter sized thermostat mounted at the top of the coils to see if it looks "popped" at the top. If it is then replace the thermostat. Hope this helps MJ
Jul 28, 2010 | GE GSS20IEP Side by Side Refrigerator
What's the best way to remove mold from fridge?
'That is the best way to clean mold is use bleach you will be okay. Just alot of work.
Jul 06, 2010 | GE PSS26SGRSS Stainless Steel Side by Side...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
GE Model PDS22MBRABB bottom mount
These fridges were made by LG they are very problematic, the defrost cysle does not work properly due to board defects and the fridge freezes up, I have replaced my board twice and the fridge has worked properly for 6 months max them the board shorts again, I talked with the LG rep he said scrap the fridge they are ****.
Nov 06, 2007 | GE Energy Star PDS22SIS Stainless Steel...
Duravit 111335001 Geberit In Wall Carrier for Wall Mounted Toilet Logo
453 people viewed this question
Top Duravit Home Experts
paulcarew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
