Question about Banner American Products QuikFinish ShredderShark 12
Problem with Banner Shredder Shark, Model # SH 92050P
We received our shredder for Christmas last year. We used it for about 1 month. It would not shut off when it was in auto mode, it would not run when I would put paper in it. There was no rhyme or reason to it.
    President:
  • 3,085 Answers
Blow some canned air down into the feed slot to clean the sensors.
Posted on Sep 25, 2009
Unit runs with nothing inserted into shredder
About 598,000 results (0.73 seconds) Search Results
    [PDF]Shredder Troubleshooting FAQ
    https://images-na.ssl-images-amazon.com/images/I/81GTHxKpz9S.pdf
    Make sure that the unit is securely plugged into a working outlet / socket. 2. If you have ... The shredder runs but it does not pull paper down. 1. Be sure the ... When ready to shred, be sure to insert material directly into the center area to start.
    [PDF]Instructions Manual
    https://images-na.ssl-images-amazon.com/images/I/71EUxqIkPNS.pdf
    you leave the shredder in the "Off" position whenever the shredder is ... To beginshredding, locate the switch on the unit and select the "Auto" mode (FIGURE 2). ...Your basic vegetable or cooking oil (nothing flammable ... a) While in "Auto" mode, the motor will not start running until paper is inserted into the feed slot. Set.
    General Shredder Troubleshooting - iThinkBlue
    store.ithinkblue.com/shredder-troubleshooting/
    Make sure that the unit is securely plugged into a working outlet / socket. ... While in "Auto" mode, the shredder will not run until paper is inserted into the middle ...
    [PDF]troubleshooting paper shredders - Ativa
Jan 31, 2016 | Shredder Office Equipment & Supplies
Where can I find a replacement pot, mine cracked after little use will be 1 yr old at christmas?
Could try the person who gave you the present and see if they still have record bill of sale, if so return to store refund or replacement? Best of luck
befor Christmas
Nov 16, 2014 | Crock Pots & Slow Cookers
I have a Ativa DQ60M Paper Shredder and it is very clogged with paper and it looks like some of the blades are slightly bent. Can it be sent in for repair or warranty?
Take away info: 3-year warranty on cutter.
Office Depot item #405935: Ativa DQ83M Diamond-Cut Shredder (mine show model ...Mn. It has a 1-year warranty for product, BUT ALSO a 3-year warranty for the "cutting cylinders". Call 1-877-777-HELP; www.ativaproducts.com .
I called 12-29-2010. Rep had difficulty finding product, put me on hold, found it. Said prod only has 1-yr w (per Office Depot online, this is all that is given as to info); but I said, no, 3-yr on cutter. I held again, rep researched and agreed. I took a case number and tried rep's troubleshooting suggestion: I put 3-in-1 oil (veg oil suggested by rep too) on the jammed shredded paper (machine still would go in reverse BTW); I let it soak 5 mins, removed paper, tried shredding, and paper jammed again. No replacement parts are avl. I called again, gave case number. Rep suggested I oil the cutter now that paper was removed. I said cutters are oiled from removing paper. I was put on hold, only a short while.
Good outcome thus far: I was given fax number and instructions to receive gift card in 6-8 weeks upon their receipt of my fax (to 1-888-561-0785) of case number, name (first and last), mailing address, and copy of the receipt.
What I learned: Do the maintenance oiling monthly or more if needed! Try to buy a shredder that is beyond my shred needs, e.g., a 10-sheet cutter but use it only up to 8 pages. Try to buy a shredder that has replacement parts.
The price of the Ativa in 2008 was $40 ($30 instant savings taken at the register), and it didn't get daily or regular use.
Good product support on this Ativa product. Glad I saved my manual and receipt!!
Dec 22, 2010 | Office Depot Ativa DQ60M Shredder
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Shredder does not turn off
You need to clean the paper feed sensors. You can call Fellowes customer service at 1-800-945-4545
Feb 11, 2008 | Fellowes Powershred P-55C Light-Duty...
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Royal Shredder
there is a small micro switch in about the middle of the paper slot, make sure it is not jammed, it should move freely and make a small clicking sound with the power off.
Jan 26, 2007 | Fellowes S701CM Shredder
Banner American Products QuikFinish  ShredderShark  12 Logo
130 people viewed this question
Top Banner American Products Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Banner American Products Office Equipment and Supply Expert? Answer questions, earn points and help others
