Question about RIM BlackBerry Bold 9000 Smartphone
My Bold won't make any audible alerts when it is ringing or when I recieve a message. The speaker works when I listen to music or watch videos but it won't ring. How do I fix it?
I recieved a message alert while listening to my music through my headphones and the player stopped. Now the player shows its running but theres no sound.
when listening to music and alert comes through the music will always pause, so that you can check the score, read alert or whatever........ to continue music just press play........ in your case shut it off and restart (boot it up again)
Mar 29, 2011 | HTC Inspire 4G Smartphone
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
My Blackberry 9000 does not ring, when called nor text, email etc. I know the speakers work, because i can watch videos, music, etc. The ring volume is at 10.
RIM is aware of the problem. For right now Just do a battery pull once a day.
Here is a link from RIM:
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB24307
Oct 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
I have a message on my sansa clip that I want to get rid of so that I can continue to listen to my book. I can't listen till this is straightened out. It says synchronize to continue your music...
Audible books are protected, you can copy them into device, but you can't play them (...subscription...appearing ). You must use audible manager to sync audible books.
You should delete audible books that make pop up a message " synchronize to....", otherwise, your device always pops up the message when it meet the audible books.
Apr 06, 2010 | SanDisk Sansa Clip MP3 Player
I have a motorola RAZR and the speaker doesn't work can it be changed?
Yes it can, but you'll need pricision tools to open it.
FYI: Speaker is used so that you can hear the other person from the other line talking.
Buzzer is used to hear your cellphone ringing, alert tones, alert tone messages, even making some music.
So in short Speaker is different from the buzzer.
Nov 01, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Blackberry Bold Speaker problem.
yes it is an hardware problem,you need to replace the ringer and the speaker to enable you to hear music and ringer to work back
Jul 19, 2009 | Lands Phones
NO AUDIO ON lgCU720!! HELP ME!!
change your speaker in your cellphone
May 04, 2009 | AT&T LG CU720 Cell Phone - Silver
No Audio
dear,
check the backside speaker of ur phone. check it if ur main ear piece is working. means that u can listen a call.
because, music in this set, relates to the back side speaker.
Jul 10, 2008 | Sony Ericsson K510i Cellular Phone
RECEIVER WILL NOT TURN ON.
first you have to test separatly your speakers outputs
disconnect all wires speaker and speakers, turn on your reciever and look if you still have the same problem «CHECK SPEAKER WIRES alert» if yes you have to go to a specialist to fix it... if no test one line after one line with and without speaker connected until the problem reappear to locate the bad line or bad speaker.
Apr 26, 2008 | Yamaha HTR-5650 Receiver
RIM BlackBerry Bold 9000 Smartphone Logo
66 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
