Question about GE Refrigerators
Recently purchased a home with a wall mounted GE Model LW11P refrigerator that is not working. Any help/suggestions would be greatly appreciated.
  • 1314 Answers
SOURCE: Auto defrost not working
a manual defrost will help in the sense that it will healp save your food now if you dont mind spending a little cash may i suggest you go buy a eurika 350 hand held steamer its great for defrosting and about 1000 other thuings around your house you canget it at lowes places like that after defrosting the unit will freeze again in about two to three days depending on how many times you open your door reply to this thered with the appox age of your unit and i can better advise from there some times as in the case of a stuck theroma stat if seen it fix them but i wouldnt count on it hold my rating tii we are done
Posted on Jan 19, 2008
SOURCE: I recently purchased a Panasonic
It's available on the Panasonic website (http://www.pasc.panasonic.com/EpartR/PartsList.asp) for under $2 plus shipping, but for some strange reason can only be purchased during business hours.
Posted on Nov 02, 2008
SOURCE: GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Posted on Feb 19, 2009
  • 56 Answers
SOURCE: GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Posted on Jun 30, 2009
jyackle5
  • 8197 Answers
SOURCE: I need a wall mount bracket for a ge spacemaker
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Posted on Sep 10, 2009
Maytag refrigerator / freezer compressor fan not running and some items in freezer appear to be thawing
Check to see if the fan mount bent somehow. The fan blade just might be jammed. If not see if the fan is getting power. The unit will not cool properly if the compressor and condenser are not being cooled down by that fan.
Dec 31, 2012 | Maytag Refrigerators
Hi, I have an a GE Profile Model TPX24PPDCC fridge that came with the home I purchased in 2006. I believe the fridge is much older. I've been having problems with the water dispenser where water will...
Yes there is a way to disconnect the water line. Pull the Fridge out from the wall. The electrical power chord should be on the back side as well as the 1/4" water line. You need to locate a valve and shut off the supply water. Then you can disconnect the line with wrenches. It is located near the bottom.
Apr 01, 2017 | GE Refrigerators
GE Top-Mount Refrigerator GTH22SHS, freon escape?
Even though technicians may wear a patch which says GE , is does not mean they are electronic refrigerator capable . Most probably know very little refrigerator repair .
From your description , it sounds like the 2 freezer thermistors could be bad . 1 is located on the freezer side panel inside a small oval housing . This thermistor tells the main control board , the actual freezer temp and when to cycle on / off . The second thermistor is located on the top of the coils , behind the inside rear freezer wall . This thermistor is " clipped " to the coils . Both are 1 " long , torpedo looking pieces , which you can easily replace ( only 2 wires to each ) . The thermistor on the coils , tell the main board the coil temperature and when to defrost .
The part number for both is WR55X10025 and cost about $10.00 each .
May 15, 2010 | GE 21.7 Cu. Ft. Top-Mount Refrigerator...
My new GE side by side fridge is great except the right hand door opens up and will hit the wall if I don't get some kind of stopper. any suggestions?
Your best bet is probably to find something to attach to the wall to catch the door handle before the rest of the door contacts the wall. I have noticed such door stops in hotels. They appear to be made of rubber, gray in color, and are about two inches wide. I don't recall seeing such things in stores (Home Depot, Lowes, etc.), but they are probably there.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE GBS22MBPABB Refrigerator not working, bottom freezer is good
check to see if the evaporator fan motor is running it blows the cold air from the freezer to fridge section. check the back freezer wall if it is iced or frosted over, you will need to check the defrost componets bimetal, heater element and timer. element and bimetal behind back freezer wall. you can check with a meter set on resistance, with unit unplugged. if the bimetal is covered in ice you should read resistance. resistance should be read on element all the time. hope this helps id start with the bimetal
Mar 18, 2009 | GE GBS22HBP Bottom Freezer Refrigerator
Ice keeps building up on coils
We had the same problem with our GE frig, a Profile 24. When the tech came out, he explained that the energy efficient models have only 1 defrost heater, but the older units had 2 and the hook up and mounting positions were still there. As long as I directed him to install the 2nd heater he could do it. It turned out the original heater was just fine, so the replacement was installed in the 2nd heater space and it has worked fine for several years now. Before doing this on yours, I would verify that the defrost timer is working and the heater unit is ok.
Jan 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
