Question about XM Radio (XMP6000)
Just bought a used car that has a satellite radio antenna on it, but when I hit the BAND button, there is no XM station. I need to get to channel 0 to activate it. How do I get there?
3 Suggested Answers
SOURCE: "not ready" message on XM radio
Remove the Audio Fuse and then put it back in and the problem is solved. So frustrating that I had to find this solution on another site as both the dealer and XM had no idea how to fix it. Dealer tried to tell me it was a bad radio and I'd have to get a replacement from Hyundai.
Posted on Jul 10, 2010
SOURCE: 2008 Hyundai Azera XM radio "not ready"
I had the same problem. My 2008 Hyundai Azera had 37,800 and my wife went over a speed bump the XM radio went off and displayed "Not Ready". I raised the hood, pulled the negative battery cable for about a minute, replaced it and fixed the problem. Only issue is, this happens every couple of days. I'll probably continue to do this till my xm subscription runs out then to heck with it.
Posted on Jul 23, 2010
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
MANUAL FOR XM SKYBOX
Unit is very straightforward to operate. Hold down O/1 button for power. Use the "mode" pusbutton to cycle thru AM/FM/CD/AUX/XM. Treble & Bass settings are made by turning the 'tuning' knob.
For radio and satellite presets, hold in the numbered pushbutton until it beeps, and then it's set. You should be able to hear previews on XM channel 1,and that will help you with antenna setup. I highly suggest using the remote XM antenna. The built-in XM antenna need to be put 'propped-up' outslde, otherwise you have to use the external antenna. Use AC power as it eats batteries, or use rechargeable D batteries. Let me know if you have any more quesions. okay?
Dec 02, 2010 | XM Radio Audio Players & Recorders
The radio on my 2010 Subaru WRX has A Sat button on the radio. How do I get an XM Tuner to activate this button?
Many/most of the original factory radios with the 'XM' button already have the tuner in them. While outside (not inside a garage or under trees) Press the "XM" button then see if you can get channel 1, or channel 247, or channel 0. Channel 1 is free previews, channel 247 is free weather, and Channel 0 is the serial number of the radio. IF you have these 3 channels then all you have to do is call 1-800-XM-RADIO with the serial number from channel zero. Leave the radio on channel 1 for 30 minutes after calling, and you should then be activated. Let me know if you have more questions.
Jul 17, 2010 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
I can't figure out how to pull the stations in
MODE picks whether you receive XM or listen to your recorded music. Press MODE so you can read a specific XM channel. Then (if you have an antenna & power) you can run the dial up & down
May 12, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Delphi Shyfi XM radio only picks up certain channels in the car cradle but picks up all of them on the Boombox. Why?
XM actually uses 2 sets of transmitters on each satellite, so it is possible you need to adjust your antenna to get the rest of the channels in the car cradle.
Sep 30, 2009 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
We had an xm radio installed in our 2010 prius after we bought it. It was ''satellite ready'' but needed the radio. We signed up for xm radio and tried to get the signal. The radio was tuned to channel...
go to who installed you sat radio have them pull the antenna and receck the the receiver number it sounds like you have the wrong reciever number even one digit off and it will never conect even tho you have preview and sat radio paired with an antenna will recieve preview
Jul 10, 2009 | 2009 Toyota Prius
XM Roady is non functional
turn ignition on and disconnect your car battery then leave it on until its done loading if it still there then call xm and have then send an update good luck....
Dec 30, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
Xm2go direct entry tuning problem
You have it set on a preset mode now. On the unit or the remote control press the "pre/dir" button a few times until you see the word "DIRECT" at the top left of the screen next to the antenna strength. From "direct" you can then key in the channel numbers directly to go to them.
Nov 15, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
Sep 08, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Sep 05, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Car Audio & Video Logo
152 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
 Mikey
Mikey
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
