Question about SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive
My flash drive (1GB) isn't being recognized by any computers when I plug it in. Can I get the info off of it some other way?
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 24, 2009
    Sniper:
  • 77 Answers
In order to resolve this problem:
First, please make sure that your USB Flash Drive is connected to the PC and please disconnect the net connection. (if any)
Now click on "Start" -> "Run". In the small window that was opened type "diskmgmt.msc" (without quotes).
This will open up Disk Management window which should show your Had Drive, CD-ROM(s) and the USB Flash Drive. You should be able to right click the USB Drive letter (I think that you said it was appearing as "H") and create a partition on it. Once there is a partition, you can format it back to the FAT file system.
I hope that helps. Plz vote for me. Thanks
3 Suggested Answers
  • 17 Answers
SOURCE: Retrieving stored data
Try this first:
http://www.flashdrivepros.com/_blog/USB_Flash_Drive_Data_Recovery_Blog/post/Help!_Windows_No_Longer_Recognizes_My_Flash_Drive!/
If not, they do flash drive data recovery as well.
Posted on Mar 08, 2010
bronk50
  • 27725 Answers
SOURCE: When I plug my Cruzer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Jan 08, 2012
I replaced a 250 RAM slot with a 1GB RAM slot. There is no difference in speed. Ran a Norton system check and it is still recognizing the 250 mb RAM instead of the 1GB RAM.
try resetting the computer, if that doesn't work it could be that your computer only recognizes 250mb or your BIOS needs to be configured.
Aug 10, 2010 | Electronics - Others
I have several pictures on my computer on Kodak Easy Share. I purchased a Toshiba USB 2.0 8 GB flash drive to transfer the pictures to the flash drive but can't figure out how to use it to transfer the...
Just plug the flash drive in and let your computer recognize it and offer to open the flash drive file up to view. Once it is loaded up then you can simply drag and drop into it. If this is the first time using the flash drive it may need to load some software. When a flash drive is being used a small icon should appear on the lower right.
Sep 08, 2009 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Sandisk doesn't recognized in computer
First connect your memory stic to other computer if it works there thne it has not any issue.
Then connect in your computer on which not recognized .
Then opem my computer if you can't see any removable storage then right click on my computer then go to its proeprty then hardware then device manager.
Then uninstall all usb drivers then restart computer then check .
If still face same issue then right click on my computer then click on manage thne go to disk management.then removable media/
check there if you find removable storage then right click on it then open or explore it.
if you still not recognized then when you power up the computer press F1 or F2 or "del' key to enter in BIOS.
Then go to advanced in bios then set LEGACY 2.0 enabled. then save settings and exit.
then check.
Aslo check your computer usb ports are working fine.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Transfer music from computer to lexar 1gb
You just need to connect the Lexar 1Hb to the USB port on your computer and let the computer recognize it and then after that double click Mycomputer and you should see there the Lexar , just double click on it and now you can copy and paste music from your computer to the Lexar...
Jan 02, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
I want to install driver of jf v30/1gb on my system
I formats the pen drive but due to the electricity cut off, format doesn't complete and pen drive doesn't recognize in computer
Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install Memorex USB 2.0 1GB flash drive on computer with microsoft 2000 OS
windows 2000 should recognize the flash drive immediately after it is inserted. The flash drive should install itself. Besides, there are only drivers available on the Memorex website for Windows 98se.
Jul 26, 2008 | Computers & Internet
Usb flash pen drive
Often it is due to electrostatic charges on usb. Unplug all USBs.Unplug PC from power cable for 10/15/ minutes. plug back computer to power outlet and restart. Plug back usb.
If it still does not work , flash memory may be faulty, test it on a different computer.
Mar 17, 2008 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
SanDisk 1GB Cruzer Titanium USB Flash Drive (413072) Hard Drive Logo
341 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
