Question about BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire
02 5 series bmw stereo
My 02 bmw stereo went on phone mode, i dont have one.Now radio and cd wont play....how can it come back to play?
  • 655 Answers
Hello rbs845,
Most vehicle audio integrated phones use a ground on a specific wire from the receiver to activate the "mute" function. If the wire contacts other wires or shorts to ground, it can cause the receiver to signal an incoming call or mute. Without the exact make and model of the receiver, it's not possible to point you to a specific wire color to look for. I'd make sure that ALL wires that are not used are securely insulated and kept from touching other wires or metal behind the dash.
Hope this helps.
Posted on Sep 25, 2009
Car will not crank. Lights & radio all work.
First thing I would do is get under the car and hit the starter with a hammer, not with everything you have, but not too gently either. The brushes in the starter are usually the culprit. So tap it two or three times medium hits, then try to start it. If it starts, you need a new starter. Keep the hammer handy, so you dont get stuck.
Make sure when you do hit the starter, you hit the body of it and not the wiring/electrical connections, this would break them beyond repair and possibly beyond rebuild condition too. Good luck!
Dec 19, 2012 | BMW 02 03 04 05 06 3 Series E46 325i 330i...
2004 Dodge stratus radio wont work
It can be radio not getting power or issue with radio code and it needs programming.
To reprogram the radio there is 4 digit code. That code has to be inserted, once these code is inserted, your car radio will get into its actual setting where you can set/select your radio setting.
Many a time's radio asks for the code after car battery is disconnected.
On some cases to retrieve the code its mentioned in manual or else car dealer is other option to get car radio code.
For more help on car radio problems, I suggest you to go through these troubleshooting links, these will help you: -----
Click the link below: ---
Cigarette lighter, Remote central locking, and Radio stopped working http://whoisbyme.blogspot.in/2012/07/cigarette-lighter-remote-central.html
VW passat radio off safe mode? VW radio CODE? http://schematicsdiagram.blogspot.in/2012/03/vw-passat-radio-off-safe-mode-vw-radio.html
How to wire new Radio on 1990 Toyota Celica?
http://schematicsdiagram.blogspot.com/2011/12/how-to-wire-new-radio-on-1990-toyota.html
Radio Stereo Wiring Diagram for 1991 Chevy 1500?
http://schematicsdiagram.blogspot.com/2011/12/radio-stereo-wiring-diagram-for-1991.html
How to remove radio on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-radio-on-acura-car-models.html
Where is Radio Fuse located on 2007 Dodge charger?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radio-fuse-located-on-2007.html
How to reset Radio code after car battery is died?
http://howtobyme.blogspot.com/2011/12/how-to-reset-radio-code-after-car.html
Can car radio code block Passkey anti theft system ?
http://schematicsdiagram.blogspot.com/2011/12/can-car-radio-code-block-passkey-anti.html
After Market Stereo wiring for 1999 Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/after-market-stereo-wiring-for-1999.html
Chevy car radio doesn't allow to switch to the XM Band to get the radio ID?
http://schematicsdiagram.blogspot.com/2012/01/chevy-car-radio-doesnt-allow-to-switch.html
No power to radio on 2005 Toyota Scion Xb?
http://repairhelpcenter.blogspot.com/2012/01/no-power-to-radio-on-2005-toyota-scion.html
Lexus rx330 Radio has power but no sound?
http://repairhelpcenter.blogspot.com/2012/01/lexus-rx330-radio-has-power-but-no.html
Radio goes ON and OFF while driving?
http://technoanswers.blogspot.com/2012/01/radio-goes-on-and-off-while-driving.html
Lincoln Town Car Radio stereo wiring?
http://technoanswers.blogspot.in/2012/02/lincoln-town-car-radio-stereo-wiring.html
Radio wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/radio-wiring-diagram-for-1997-lincoln.html
How to remove cd player from dash on 2003 Lincoln Aviator
http://technoanswers.blogspot.in/2012/01/how-to-remove-cd-player-from-dash-on.html
These details will help you thanks.
Nov 24, 2012 | 2004 Dodge Stratus
Bluetooth Samsung Galaxy s3
Turn on bluetooth on phone.
- settings-bluetooth > on
Turn on bluetooth in car stereo
- Turn on radio, press Menu.- Scroll with knob to Phone. - Press knob to Select.- Turn knob to select Pair.
Back to Phone
- Hit the Scan button to search for BMW bluetooth- Find BMW Bluetooth name on phone and select Pair. - If should ask for a passcode, enter identical pass codes on stereo and phone.
Nov 05, 2012 | 2006 BMW 5 Series
My 2004 Chevy Malibu Maxx LS Multi CD/Stereo player won't play CD
For Radio related problem,the help links are below.Click the link below to go through its procedure:-----Car radio works but CD player not working?http://technoanswers.blogspot.in/2012/02/car-radio-works-but-cd-player-not.html-----------How to reset Radio code after car battery is died?
------------- Can car radio code block Passkey anti theft system ?
How to wire new car Radio?
Radio Stereo Wiring Diagram?
How to remove radio on Car models?
Where is Radio Fuse located?
----------- After Market Stereo wiring?
No power to radio Scion Xb?
Radio wiring diagram for Car?
How to remove cd player from dash?
This will help.
Thanks.
Mar 05, 2012 | 2004 Chevrolet Malibu
JUST GOT A BMW 740 CANT PLAY RADIO? OR UISE NAV ANY1 KNOW WHAT THE PROBLEM IS
CHECK THE SUPPLY FUSE, THEN THE PLUGS INTO THE RADIO/NAV UNIT, FAILING THAT MIGHT BE A FUSE ON THE RADIO/SAT NAV THEMSELVES BUILT IN
Feb 15, 2011 | BMW 1997-2001 Bmw 5 Series Radio/stereo...
Only door speakers have sound on the cd mode
the amp requires a 12 volt power constant, and a 12 volt "on" signal. you prolly have the 12 v "on" hooked up to the car stereo's antennae remote, meaning your amp gets power when the radio is on, cuase the radio is sending a signal to the amp (thinking that it is sending a signal to the antennae to raise)
you do have one of those collapsable antennas, right?
Mar 12, 2009 | Clarion VRX745VD Car DVD Player
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
My Bmw 325 SE cd player wont work...but the radio is working
   The carriage inside the cd player is half way in mode.  Which means the cd has to be removed mechanically.  In order to do this a qualified technition needs to dismantle it.  On some models there is a reset switch next to the eject button on he changer.  It will be very small.  like the size of a paper clip hole. push in with a pin.  Otherwise go to stereo shop
Jan 07, 2009 | 2001 BMW 325
BMW 02+ 3 5 X5 M3 Series Car Radio Wiring Harness Wire Logo
278 people viewed this question
Top BMW Car Audio & Video Experts
xxxxxx xxx
Joseph Hoffmann
Are you a BMW Car Audio and Video Expert? Answer questions, earn points and help others
