Question about Maytag Atlantis MDE7400AY Electric Dryer
Replaced the electrical cord on maytag atlantis dryer < a year ago, but now it seems the hot connection is burning up.
    President:
  • Maytag Master
  • 1,922 Answers
BOTH HOT "L1" and "L2" connections or just one of them is burning up? if just one you could have a partially shorted heating element drawing excessive current
Posted on Sep 25, 2009
My Maytag Atlantis gas dryer is making a sqeeling noise and sometimes will not turn the drum, unless i hand turn it and my run, i open it up but nothing looks out of order, the motor smells as if it is...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag atlantis dryer and im trying to hook it up to a 4 prong hookup and there is only 3 wiring connections on this dryer
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Trying to hook up three wire plug, witch wires go where? maytag atlantis mde6400ayw
the red and black go to terminals marked L1 and L2 polarity isnt an issue here,and the white or bare is the N terminal or neutral connection,if its non color coded cord as in gray insulated then the 2 outside conductors are the 2 hot wires L1 & L2 and the center is N neutral
Jan 09, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis Dryer pull-knob won't start dryer
sad!! To Say!! It's a bad Timer!!
Maytag went cheap on there Timers!!!!!!!!!!!
I Work on them and have been in a few homes and had to replace them even less then a year old!!!!!!!!!!!!!
Sep 13, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer
Replace the cord first. You won't be able to tell for sure unless it's replaced. Dryers pull so many amps and the dryer cord becomes hot while running it. The heat causes them to break down over time.
Apr 10, 2009 | Maytag PYE2300AY Electric Dryer
Maytag atlantis
Usually you will encounter a situation where a wire will burn off and in so doing, it may trip a breaker,(turn it off then back on to be certain), or if fused, it may blow a 30 amp glass fuse or 30 amp cartridge fuse. Replace both tho eliminate any doubt. If all checks ok, disconnect the dryer from the power source and go internal to find the problem. Below is a popular link to provide you with more assistance, should you need it.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Jun 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
94 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
