Question about Nokia 7650 Cellular Phone
My personal cellphone nokia 7650 was lost.
Im going to mall with my parents. my cellphone was in my pocket. in i can see my cellphone in my pocket he was lost now.
2 Suggested Answers
Abe Atok
  • 129 Answers
SOURCE: nokia 7650
whether you have changed the buzzer? Check the buzzer first. you can use a multimeter, if the buzzer is still good, this means that the ribbon cable problem, you need to change the ribbon cable.
Posted on Aug 07, 2010
  • 32281 Answers
SOURCE: i lost my phone nokia 5800 xpress music last april
It is near impossible to recover your cell phone.
I suggest you contact your cell phone providerASAP. To lock your cell phone from further use, please click on this link :-
Posted on Apr 29, 2011
0 characters
1 Points
I have lost my security code i have change it from default to personal number phone model is nokia 6300 emie no is 359317029767683
To unlock security code.You must go to a cellphone technician.They have a program how to unlock any previous setting..
Jun 18, 2011 | Cell Phones
Bluetooth Connection Guide Part 1
This is a "How To" for Connecting the Nokia Series 60 device (Nokia 7650, 6600, 3650, 3660 etc...) via Bluetooth TM with the Windows Widcomm software used by TDK, Billington, MSI and others Bluetooth USB Vendors. The steps are similar for other Series 60 devices and have been checked with the 3650 and 6600.
1.Pairing the computer and the Series 60 Handset
Pairing is the process of swapping pass keys and setting up a trusted connection between the Bluetooth USB adapter / card connected to the PC and the 7650 handset. Save any files and close any applications you may have been working on.
2. Set up Bluetooth TM on the 7650 by going to the Main Menu, selecting Connect and then Bluetooth.
3. Make sure the Bluetooth option is On and My Phone's Visibility is Shown to all. Remember what is in My Bluetooth Name - or edit it to one of your choice - this is what your 7650 will be seen as by other Bluetooth TM devices.
4. Right Click on the Bluetooth Icon in the system tray, on the menu that appears go to Setup and then click on Security.
5. A window appears and all being well the right hand pane will have your 7650 (titled what ever you have entered into the phone's My Bluetooth Name entry). If nothing appears click Refresh and your phone should then appear. Highlight the 7650 and click Execute Pairing.
6. A window will pop up asking for a PassKey. Enter in a numeric only passkey and click OK.
7. On the 7650 a screen pops up asking you to enter a passkey - key in the same number you just typed into the PC.
8. By default any connections from your PC to the 7650 must be manually accepted on the 7650. You have an option to set up a connection from the PC to your 7650 as authorized, this means when you connect from the PC to the phone it won't ask you if it's ok and will connect automatically.
9. To set it as automatic: On the 7650 in the Bluetooth TM Setting Screen, you joystick right to the Paired Devices screen, highlight the Computer you just paired with and press Options, select Set as Authorized and Yes. You will then see a padlock icon beside the paired device - this device will no longer require manual authorization for connections to the 7650.
Now you should set My phone's visibility to Hidden - so that unknown devices searching won't see your phone. You can still be connected to by any paired devices. Remember to switch it to Visible if you want to pair with a new device or receive a file / business card from someone with an unpaired device.
on Mar 06, 2010 | Cell Phones
I want full body of nokia 9500 where i can get original
hi there!
did you mean housing (casing) for you phone? that depends on which country you're at, but you can buy that from your local malls, just go to their technical stores (cellphone stores). or if you have a nokia outlet there too. post again with your country so i can look up for stores near you!
Apr 07, 2011 | Nokia 9500 Communicator
Re: dubao 302 mobile from china
try going to greenhills or in victory mall in caloocan. there are lots of cellphone techinicians in there who will be able to check and repair your china phone.
you can also try going to guadalupe mall.
Aug 09, 2009 | Nokia N95 Cellular Phone
Its battery problem
if you already change your battery and still have the same issue.
i think the problem is not in the battery anymore.
you can send your unit to a service technician personal to check the charging unit if it is still ok or need to change.
May 28, 2009 | Nokia 7650 Cellular Phone
Sim not valid
Type of your Cellphone: 7210, 6310i, 7650 .......
Your IMEI in this Format (15digits) 123456789012345
( Not like this 0101-1450-0748-923 or 123413-12-121112-1 ... )
Your Network Code: xxx-yy
(For example if your phone is locked to Orange type 234-33)
Jul 10, 2008 | Nokia 1110i Cellular Phone
Unlock phone
anyway,where you from? must go to the mall, who have selling or buying a 2nd hand cellphone, and then ask the person if they can unlock phone..because here in manila, philippines, most of all supermalls here, are unlocking the unlock phone, just like what happen to your phone..
Feb 26, 2008 | Motorola Mobility V360 Cellular Phone
How to openline N73 cellphone
if you give me your imei numner i can talk you through how to do this but need your imei number to get the code for your phone as they are all different ok speak soon
Oct 26, 2007 | Nokia N73 Cellular Phone
Nokia 7650
Aug 31, 2007 | Nokia 7650 Cellular Phone
Nokia 7650 Cellular Phone Logo
22 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
