Question about Kenmore 46462 Front Load Washer
Item lodged under drum Kenmore HE2 46462
A lighter is lodged under the drum. I can see it if I pull back the bellows but I can't get it in the right direction to remove. How can I access the area around the silver drum? I asked before but misspelled access so the reply was to see it.
    President:
  • 1,185 Answers
Take the back off the washer lay the drain hose down into a bucket so that the water drains out
Check to see where the main drain hose comes out of the bottom of the outer container
Lay the machine down onto some cushions so that the hose opening is nearest to the floor
Take off the clip securing the hose , place a cloth under the pipe and pull it off
You should then be able to go fishing for the item
Good Luck
Posted on Sep 24, 2009
Testimonial: "great advice..ty"
When I go and try to run the cleaning cycle, the machine will start to spin, then puts no water in and after about a minute en rL error is display. Some time the clean cycle will start with out a problem...
"rL" indicates a garment has been detected inside the wash tub. Garments are detected by weight. The wash tub must remain empty during a Clean Cycle. If you inspect the wash tub and it appears to be clear, inspect the area around the door bellow (rubber door seal) for loose items. It is common for small garments, such as socks and underwear to get lodged in the rubber folds. Pull back the folds around the door and inspect the perimeter of the seal. If you need further guidance please let me know. I hope this helps you.
Jul 26, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore front loader object stuck under drum
Sugest you remove the heating element and use a torch to see item through hole then pull out in the best manor possible.
Sep 24, 2009 | Kenmore 46462 Front Load Washer
Need part number for rubber boot on my kenmore elite HE3t washer
The part number is 8182119 and can be viewed at searspartsdirect.com. Just type in your model number and look for item number 5 under the "Door and Latch Parts" heading. In addition, you may not need them, but just in case, you may consider the inner and outer bellow clamps that hold the door seal in place. This are items 6 and 14 under the same heading. Sometimes they become damaged. If you need instructions on how to replace the door bellow, the following link explains:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions along the way, please let me know. I hope this helps you.
NOTE: You can find this part a little cheaper at appliancepartspros.com. Just use the "Search By Part Number" selection as your search criteria.
To keep the new bellow from mildewing, it is recommended by the manufacturer that you leave the washer door open while not in use and to periodically clean the bellow. Pull back the rubber folds in the door and make sure you do not have anything stuck that will cause odors and mildew. Small garments such as socks and underwear can commonly get stuck in this area of the door. Also, if you do not routinely use hot water, it is recommended that you run a "clean" cycle with a small amount of bleach about once a month to kill any bacteria.
Jul 01, 2009 | Washing Machines
My HE2 front loading washing machine smells
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 03, 2009 | Kenmore Washing Machines
Kenmore HE2 plus 11047532601
If it's stackable, you'll want to start by removing the dryer.
Open the door and remove the outer bellow spring around the bellow to release it from the cabinet lip. At this point lean the machine back to give more space between the drum and the cabinet.
Remove the kickplate for easier access and to visually check for leaks later.
At the top/right of the bellows (close to the tub) loosen the bellow to tub clamp and pull out the bellow.
Install the new bellow starting at the top by aligning the marks. Work your way around until bellows is properly seated snug against the tub.
Replace the tub to bellow clamp and tighten it (make sure the bellow stays snug against the tub while tightening the clamp). Once in place, lay the machine back to level and reinstall the front of the bellows to the cabinet with the outer bellow spring clamp.
With towels handy (just in case), let the machine fill and agitate for a few minutes and check for water leaks. If all is well, re-install the kickplate and wash some laundry.
Feb 22, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite duet 410 metal wire for gasket came off
is it a metal wire connected at bottom with a 2-3inch spring???? is so it secures the "bellow to the front lip of the machine. youlll need to stretch it over the front "bellow lip after installing the "bellow"
Sears Kenmore HE2 front load washer
there is a spring around door opening that holds bellows on remove it and pull back from inlet opening also possible if you use dry detergent a lump has become lodged in fill line working something from both ends may dislodge it
Nov 26, 2008 | Washing Machines
He3 bellows
Alright first I would check the level front to back and get a linen bag designed for the smaller items. Second I would test the basket by pulling slightly and lfting, if no wobbles then ok try push pull to check for a loose spindle at the flywheel on the back.
Jun 15, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 46462 Front Load Washer Logo
139 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
