Question about Kodak Advantix Film Drive FD 300 Path-Through Scanner
Scannin process abruptly ended with partially finished photo, grinding noise from FilmDrive; film jammed, failed to rewind. Note appeared on screen: " ADVANTIX ACCESS SOFTWARE UNABLE TO COMMUNICATE WITH FILMDRIVE, etc..... refer to troubleshooting software." I was able to open film access door, removed cassette and pulled-out jammed film.Perhaps film segment remains within. The FilmDrive is inoperative. Incidentally indicator light on front of FilmDrive remains unlit.
  • eehrlich Sep 24, 2009
    I'm not sure that your advice is really relevant to Kodak Advantix Filmdrive FD 300. It is a fully enclosed unit without easy access to its inner working parts. I have no way of checking gears for lack of lubrication or for them being off center. There is no power button, Operation of the unit is dependent upon software The device normally is activated by film drive software provided by Kodak and is activated by clicking on desktop icon "FD 300 Launcher". Are we working on the same page? Ed Ehrlich
  • 11,896 Answers
You plastic gears may have lost there lubrication of lithium grease and could be catching and grinding. Or the gear may be off centered. Hopefully the motor is not failing. You can check and run it with gear off to see if it spins continuously. Check to see that gears aren't jammed. Try unplugging the unit for a few hours, press the power button while unplugged, after that and plug back in to see if the unit reset itself.
Posted on Sep 24, 2009
  • Nate Stansfield
    Nate Stansfield Sep 24, 2009
    I recommend updating any software for this machine possible. You will have to download the software update from the manufacture's site and transfer it to your machine.
  • Nate Stansfield
    Nate Stansfield Sep 27, 2009
    The software/firmware of the unit will have to be updated for this machine to work. You can get an update from manufacture's site, The machine will have to be on and connected for it to work. THere are some videos on youtube and howstuffworks that will describe how to perform the update.
My 35mm film won't load. It keeps rewinding
Solution: Repair or replace auto-rewind system.
Cause: The built in auto-rewind system that supposed to work when film is finished but because it is faulty it receives wrong signal when film is lloaded. So the camera thinks the film is at the end of the roll.
Possible cost: $65-$75
Oct 26, 2012 | Photography
I am having trouble unloading my holga 135mm. I finished taking pictures on my roll, and now when rewinding it so that all the film is back in it it just won't do it. Before this happened, when ever I...
This probably means that the film did not wind on to the take-up spool, so no photos were recorded. Check the results when you process it - if its completely blank, that is what has happened.
Aug 11, 2017 | Holga 135BC Film Camera
I accidentally pushed the film release button before finishing my film, and it won't pop back out. it won't let me take pictures too. how do you fix this?
The mechanism won't re-engage until you open the door (camera back) and shut it again, then wind on and fire a few shots as if starting a new film. You could open and shut the door in total darkness, and then waste a few shots to carry on with the film in the camera, but the frame counter will be wrong. Unless there is a lot of film left on the cassette, you might as well just rewind it and start again with a new film. Yes, you will probably be paying more than you should for the processing and printing of a partial film, but you will get your pics.
Jan 09, 2011 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
Film has not rewound but has 'reverted' to showing
On the toplate of the camera, to the left hand side, is a button which slides to the left. It is marked with a film cassette outline, and two arrows to the left <| <|
At any time, you can use this button to rewind the film back into the cannister. It should make a whirring noise for 5-10 seconds, and will stop automatically.
If it makes no noise, you may have a flat battery, or the film may already be rewound.
You can insert new power (battery) without affecting the film cassette, if need be.
However, if really unsure, then:
1) Slide the rewind button to rewind(i.e. to the left).
2) Familiarise yourself with where the back opening latch is.
3) Go into a pitch black room. Preferably under a quilt in a pitch black room.
4) Open the back and take out the cassette. If it comes freely, its probably fully rewound. If its still attached to the take-up spool by film, then (holding the film by the edge only) pull on the film to release it slowly from the take up spool. Whilst it can be quite a tug, they are designed to let go of it "under protest". (Do not pull it so hard that you strip the gears, but fairly firmly).
5) Using the spool winder on the top of the cassette, wind the trailing film back into the cannister. If you've never seen a 35mm cassette, then in the dark one end has an elevated round part, the other end has a void into the cassette. You can tell the elevated part, and start winding - it should only wind one way and feel like its winding onto the reel (wind the other way and it feels like its unwinding - even in the dark!)
6) Only when you are sure film is in the cannister, can you turn on the light.
Films are very sensitive to light, so if you do not feel comfortable doing this procedure in total darkness, go to a photo processing store who will do this for you, usually for no charge (other than the hope you'll let them process the film). They put your camera in a sort of black pillowslip, but the procedure is the same.
Hope this helps
Jan 20, 2010 | Olympus SuperZoom 700BF Film Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Kodak Advantix Film Drive FD 300 Path-Through Scanner Logo
132 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
