Question about Samsung CLP 300 Laser Printer
Says transfer belt error, do i need to replace or can i fix?
    President:
  • 1,462 Answers
HI,
The Transfer Belt error is because it is not correctly installed or it is defective,if so it need replacing.
You can Pull out of the Drum Unit, open front door and take out the whole assembly
Then you can look on the Transfer Belt, You can pull it out,
CAUTION: it is difficult to get it back into position again if your not sure what your doing.
You can replace the belt for around $40/$60 for the item + technician fees
Please RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Sep 24, 2009
I have a problem about transfer belt error 14
Error 14 is actually the transfer roller, error 16 is the transfer belt.
Error 14 is a transfer roller error and roller needs to be replaced. The part number is 059E05450 and can be ordered below:
http://www.iteminconline.com/059e05450_059e05450-xerox-6120-transfer-roller.htm
Jul 30, 2015 | Xerox Phaser 6120N Printer
Error 917
917 Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
Code 917: The Transfer Belt Rotation Sensor indicates a belt error.
Initial Actions:
? Check the condition of the Transfer Unit drive gear.
? Cycle the printer's power.
? If the problem persists follow the procedure below.
Troubleshooting Procedure Table
1 Test the Belt Rotation Sensor.
Run the Service Diagnostics Belt Hole IC test.
Does the sensor function correctly?
Yes) Go to Step 2.
No)Replace the sensor. If the error persists, go to Step 3.
2 Test the Transfer Unit Motor.
a. Close the Interlock Switches for test.
b. Run the Service Diagnostics Transfer
Belt Motor test.
Does the motor operate?
Yes)Replace the Transfer Unit. If the error persists, go to Step 3.
No)Replace the motor. If the error persists, go to Step 3.
3 Check all pins on the HALL1 Harness for continuity.
Disconnect HALL1 and P/J310
Is the harness conductive?
Yes)Replace the Motor Driver Board.If the error persists, go to Step 4.
No)Replace the HALL1 Harness.
4 Check all pins of the DRV0 harness for continuity.
Disconnect the DRV0 ribbon cable.
Is the cable conductive?
Yes)Replace the Engine Control Board.
No)Replace the DRV0 Harness.
Aug 18, 2011 | Xerox Phaser 7400/DT Laser Printer
There is an error message being displayed that says "Transfer Belt Error" does this need to be replaced or is there a way i can manually fix this?
Since you didn't say which printer, I'll give the general answer.
Reseat the transfer belt. If the error persists...replace it.
Jul 17, 2011 | Office Equipment & Supplies
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
How to fix transfer belt error in my samsung CLX3160fn
3. Select Tech Menu
4. Select DataSetup
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
• Dirty Sensor
• Defective sensor
belt unit.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
control board
Sep 19, 2009 | Office Equipment & Supplies
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer was off for two weeks and now error sc471
SC471 means: Belt tension unit cam error. Even though the belt tension unit tires to return to its home position several times, the home position sensor is not activated.
Possible Causes:
Defective transfer belt unit.
Defective transfer belt tension unit.
CN25 Pin 3 on the engine board is unable to send a signal.
Suggested fixes:
Replace the transfer belt unit.
Replace the engine control board.
Replace the transfer belt tension unit.
I would start by opening it up and inspecting the transfer belt and associated parts. Pull them out and re-seat them. Look for broken wires, stripped gears, gunk in the works. Clean it, then put it back together and test.
If you aren't up to it, it is probably time to call the repair man.
Dec 16, 2008 | Ricoh Aficio CL2000N Laser Printer
Transfer belt errors
I saw this posted somewhere on the internet and it worked for me.
Take out the transfer unit and look at the bottom. One side has visible wires. Open the side panel on that side. Follow the 3 wires to a C shaped sensor held in with a screw. Remove the sensor and blow canned air in the slots on the inside of the C. Put it all back together and hope for the best.
Sep 30, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP 300 Laser Printer Logo
366 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
