Question about Fujitsu Siemens AMILO Pro V2010 Notebook
My laptop computer fan is not working and the laptop gets hot and shuts itself off and sometimes has no sound
  • 822 Answers
Please change the fan as soon as possible to avoid serious damage to *********** board.
Posted on Sep 24, 2009
Computer get hot and shut down
Clean the fan. The fan is probably getting hot and the computer has an automatic shut off. To help with this issue, update the bios of the computer. Just google your computer type and the newest bios.
Oct 19, 2012 | Sylvania G-Netbook
My Sony Va 10 VGN CR21Z/R shuts down automatically when I'm doing my work
check the air outlet at the bottom side .does the recirculating fan work ?most probably the fan isnt working ,leading to the laptop getting hot and switching itself off to protect other components from damage .
Apr 26, 2012 | Computers & Internet
My laptop will startup but as soon as it reaches the loading for windows it shuts itself off.
The problem you have can be fan problem.
If the laptop is still under warranty you should take it to assistance.
Mar 01, 2011 | Computers & Internet
When i am ueing the lop top it get hot and shut down i have to wait antill it cool down before it start up again
it sounds like your cooling fan has stopped working therefore the cpu is getting too hot to work and will shut the system down have the cooling fan looked at
Oct 29, 2010 | Compaq Presario CQ60-220US PC Laptop
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
May 04, 2010 | Toshiba Computers & Internet
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
My laptop gets heat and shutdown
Solution:
Feb 27, 2010 | Compaq Evo N610C Notebook
Inspiron 6000 powers off by itself
It could be that your laptop is overheating. Most computers have a heat sensor that will shut down the system when it starts to get to hot. Next time it shuts down, check to see how hot the air coming out of the fans on the laptop is. If the problem is overheating, be sure that you always have it sitting on an area that allows the fans to push the hot air out of the laptop. If it still overheats, you may want to get a can of compressed air to clean out the fan itself.
Hope this helps.
May 12, 2009 | Dell Inspiron 6000 Notebook
When i am working on my HP laptop Compaq 6515b, sometimes, it suddenly shuts donw,and the laptop itself is extremely hot. sometims, it took 5 mins to open a word file. Someone told me that maybe there...
Hi, the problem sounds to me like your CPU is overheating.
Have a look or have a technician look at the cooling fan and see if it is still working.
Most CPU's are set to shut down when over hot to prevent damage.
Regards mistyman
May 08, 2008 | Computers & Internet
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
277 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
