Question about Sony Cyber-shot DSC-W55 Digital Camera
Removal of RealOne player
I am unable to remove RealOne player from Add or Revove programme. I have revmoved the files from real folder in programme files. when I try the result displayed is " uninstaller component missing". please advise how to remove completely the RealOne Player from my computer.
I want to delete the Real Player program from my C drive. But when I try to do the same - it says "Uninstaller Component missing". How can I delete the program from my PC?
Posted on Dec 31, 2008
You may go to C:\Program Files\Real\RealOne Player\realplay.exe. in case if you find the file delete it . usually in this error the file wont be there use the link below to use a tool that will help uninstall real one player.
http://www.lillevold.com/files/r1pclean.zip
Posted on Jan 03, 2008
  • Rajeshprabhu Jan 03, 2008
    Even after uninstalling, there is still alot of debris (http://www.click-now.net/forums/lofivers... left.
    If you want to install again, maybe you can take a snapshot with Total Uninstall. http://www.martau.com/).
    Then in the future if you want to uninstall again you simply uninstall normally then use TU.
    Champion:
  • 209 Answers
You may go to the program files of your drive c: then highlight this file then press delete, you should also delete manually,click the start then all programs then look for this file
Posted on Dec 16, 2007
I have 2 or 3 programmes I cant remove useing add or remove feature in control panel one being tuneup utilities and the other being McAfee security scan plus I have not downloaded these programmes and have...
Hi ...in most cases download programs come with their own un-install feature. Check in your "Program Files" folder for the names of the program you want to un-install> click on each folder to open and see if it has an uninstall icon in the folder...if so click on it and BINGO!
Sep 15, 2011 | Microsoft Computers & Internet
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Loading music
There is an alternative to loading song onto your friends mp3 players like all players.
Many people find it difficult to sync there mp3 with windows media player, because it can be very annoying.
To get around this, First: Connect the mp3 player to your computer.
Next, got to my computer.
You should see the mp3 player in there as a removable disk,
Right-Click on the removable disk and select "explore"
This will open a window showing all unhidden files/folders in the mp3 player.
Leave the window open,... next find the music you want to add to the mp3 on your computer.
Windows Media Player music can be found in the my music folder.
Once you have discovered the music you want to add to the mp3 player, go to the mp3 player folder (removable disk).... there should be a folder in there labeled music.
From here on it's just a simple drag and drop process.
Select all the music file you want on the mp3 player from the my music folder, and move them inside the music folder found on your mp3.
Hope this help <(^_^)> thanxx
Apr 23, 2009 | Audio Players & Recorders
How to completly remove ESET
Hi there.
Download CCleaner, install it and use the cleaner to delete temp and temp internet files, then you want to clean the registry, when you click on fix selected issues make sure you back them up to the registry, keep on scanning for issues and fixing them until no more issues are found, restart the PC and try to manually delete the left over ESET folders.
Post back if you still can't get rid of the old folders.
Good luck and thanks for using FixYa!!
Mar 13, 2009 | Computers & Internet
On the VL-340 I can't change/add music because of a write-protect
use the sync option w/ yer Windows Media Player .. i just added 1.56G of music on my element gc-920/940..right click the music file (in WMP) and select "add to sync list"...then click button on the bottom of the list that says"Start Sync"...hope this helps
Dec 25, 2008 | Visual Land VL-340 MP3 Player
Unable to remove programme
Try to unstall using the add/remove program.
Here's the step
1. Click start
2. Click control panel
3. Click add/remove program
4. Choose the program you want to remove then click remove.
Hope that will solve your problem
Thanks
Dec 01, 2008 | Philips J44414
Uninstal AVG 8
GO TO CONTROL PANEL ON YOUR PC AND LOCATE ADD AND REMOVE PROGRAMM THEN CLICK ON THE APPLICATION YOU WANT TO UNINSTALL THEN UNINSTALL IT AFTER THAT GO TO YOUR HARD DISK DRIVE C LOCATE PROGRAMM FILES THEN OPEN IT AND LOCATE FILE OF AVG8 AND DELETE IT BUT YOU MOST FIRST UNINSTALL FROM CONTROL PANEL BEFOR DELETING THE FILE. HOW TO GO TO CONTROL PANEL, CLICK ON START MENU LOCATE CONTROL PANEL CLICK ON IT THEN LOCATE ADD OR REMOVE PROGRAMM AND CLICK ON IT WHEN OPEN CLICK ON THE PROGRAMM NAME YOU WANT TO REMOVE AND AT THE RIGHT HAND SIDE YOU WILL FIND (CHANGE/REMOVE) CLICK THEN YOU FOLOW THE INSTRUCTIONS. AFTER FINISH THE UN-INSTALL YOU CAN INSTALL THE NEW ANTI-VIRUS
Nov 20, 2008 | Computers & Internet
REALPLAYER DOWNLOAD FOR IMATE KJAN
my pocket pc on display two color
Jul 07, 2008 | i-mate K-jam Smartphone
I have downloaded videos from YouTube using real player, and when I try to add them to my RCA Opal, the video converter won't read the file.(possibly since its from real player) When I go to its internal...
Make sure you have copied the file to the correct folder in your Mp3 player. Sometimes if it is copied under a different folder, you will have the issue you have just described..
May 15, 2008 | RCA Audio Players & Recorders
Unable to delete files through PC
try to open new session with an administrator count
Jun 03, 2017 | Toshiba Gigabeat MEG-F20K (20 GB) MP3...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
