Question about Radio Communications
New Radio Shack Pro-197 Digital Scanner. Set up by Radio Shack staff with info from this site: http://www.radioreference.com/apps/db/?ctid=304 Town: Darien CT We are a local newspaper. Scanner set up identical to same scanner in another town (diff frequencies) yet we get nothing. We are no more than 3 blocks from Police station. Please help.
3 Suggested Answers
SOURCE: Program Some Channels
help. I am locked out of my 97 pro.. I was listentenig I pushed a button and it loicked. Radio shack says they cant figure it uot "read my Manuel!!"
Posted on Jan 27, 2008
Ironfist109
  • 3018 Answers
SOURCE: i have a uniden bearcat bc 147xlt and it use to
  • Try these steps to program your scanner to make sure the frequencies are in proper and don't forget to add the decimal [.] point.
  1. 1. Press "MAN."
  2. 2. Press #1.
  3. 3. Press "MAN."
  4. 4. Now enter your frequency.
  5. 5. Now press "E" for Enter.
  6. 6. Now you have a frequency programmed. Repeat steps above to save more frequencies.
  • You could be having a problem with your antenna too. Might want to check the soldier joints, condition of or antenna replace it. The repeaters for N.O.A.A. transmit with more power and puts out a much stronger signal out of their repeaters than the local municipals will. So it is not uncommon to pick up weather and not some of the local frequencies. Especially if you are trying to pick up frequencies in a county rather than in a bigger city.
  • Let me know if you have any other question.
  • Hope this helps.
Posted on Nov 07, 2011
How do i reset my radio shack 197 back to factory
The information is found on pages 90-92 of the owners manual, which you can download for free in PDF format from the link below.
Remember: Erasing like this is permanent, make SURE its what you want to do.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000197_PM_EN.pdf
Jul 08, 2014 | Radio Shack Pro-97 Handheld Scanner
The model is pro197. I need customer comments on this scanner. Iam unable to get this information up.
Try following this link to the Radio Reference forum:
http://forums.radioreference.com/radio-shack-scanners/129895-pro-197-review-likes-dislikes-comments-thread.html
It has a lot of info on the PRO-197, and you can post any questions that you might have.
Bill B.
Listening in since the 60's
Feb 04, 2011 | Radio Shack Pro-2096 Base Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
How to program diginal trucking on a radio shack pro 197 diginal scanner
Digital trunking systems require detailed programming steps, and those steps vary according to the type of system you need to program. The manual for your scanner provides step-by-step instructions for each system type, and I recommend that you familiarize yourself with its contents. If you don't have the manual, you can download and print it here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000197_PM_EN.pdf
If the information in the manual seems overwhelming, you might want to join a user group (check Yahoo Groups and RadioReference.com) or consider using available programming software programs.
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning info, visit:
Bill B
Mar 05, 2010 | Radio Communications
Radio Shack PRO197 works at friend's house but not at my house!
This seems to be a common problem with all digital systems (especially with TV signals), and the ONLY solution is a better antenna. I suggest you search eBay, Scanner Master, etc. for a low-end (price-wise) discone and mount it as high as you realistically can.
The BEST scanner in the world is only as good as the antenna that feeds it!
May 30, 2009 | Uniden BCD396T Handheld Scanner
What Type Of Scanner Do I Need?
Well, the above answer is somewhat correct, but could use a little clarification.
A radio that transmits in a P25 format is digital. Digital transmissions can be trunked, but don't have to be (as is the case here). In the case of scanners, every major brand scanner out there that works on digital transmissions will decode trunked of conventional digital and analog transmissions.
The current digital models run anywhere from $399 to $599. Radio Shack has 2 newer models out that will do digital...the PRO-106 (handheld) and the PRO-197 (base/mobile). These have been on sale recently for $399. Uniden also makes digital trunking scanners..the latest models being the 396 (portable) and the 996 (base/mobile). While the 996 has the capability to be used with a GPS in a mobile setting, this feature isn't really worth the added cost, especially when compared to the feature rich PRO-197.
There are older model digital scanners, such as the Radio Shack PRO-96, PRO-2096 and the Uniden 250D and 796D. While these receive digital transmissions, the newer scanners have upgraded digital decoding algorithms that provide better audio quality and intelligibility. Also, the older scanners may not be able to decode the 700 MHz public safety band, which is becoming increasingly more popular since the 800 MHz band is quickly filling up.
One word of caution...be sure that the agency you are trying to monitor is not using encrypted transmissions. If you don't know...look up the system on radioreference.com. Channels that are encrypted usually have an "E" designation under the "mode" column. These transmissions CANNOT be decoded by any of the scanners currently on the market, even if you do have the encryption key.
I hope this helps you with your buying choices. Good luck!
Sep 11, 2008 | Uniden BC72XLT Handheld Scanner
Radio Communications Logo
455 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
