Question about Fantom Titanium Hard Drive
I have an external hard drive and something changed in the registry as there is a bunch of mumbo-jumbo letters for location. It just blinks and does not show that it is hooked up in the computer. Red power light is on, but blue blinks all the time. What is the matter.
  • 1,472 Answers
Delores684
It sounds like some other device might have taken the drive letter that we assigned to your external hard drive. The links below will show you how to change the drive letter.
Let me know if you have any more problems or questions
Issken
How to change your drive letter in Windows XP
http://www.fixya.com/support/r4183994-change_drive_letter_in_windows_xp
How to change your drive letter in Windows Vista and Windows 7
http://www.fixya.com/support/r4176803-change_drive_letter_in_windows_vista
Posted on Apr 15, 2010
My seagate external 1tb will not load said that parameter is incorrect ...what can i do it is about 1/2 full..
You must be logged on as an administrator to perform these steps.
If you don't like the letter Windows has assigned to a new drive or you want to organize your drive letters in a certain way, you can change the drive letter.
You can assign the letters C through Z to each drive on your computer.
A and B are usually reserved for floppy disk drives, but if your computer does not have floppy disk drives, you can assign A and B to volumes.
You can see which drive letters are used on your computer by opening Computer.
Open Computer Management by clicking the Start button, clicking Control Panel, clicking System and Maintenance, clicking Administrative Tools, and then double-clicking Computer
Management. If you are prompted for an administrator password or confirmation, type the password or provide confirmation
In the Navigation pane, click Disk Management
Right-click the partition or drive that you want to change, and then click Change Drive Letter and Paths.
Do one of the following
To assign a drive letter if one has not already been assigned, click Add, click the letter that you want to use, and then click OK
To remove a drive letter, click Remove, and then click Yes to confirm that you want to remove it.
You might need to do some diagnostics to find out what is wrong.
If you have nothing to lose, format the machine.
or
You have to erase the entries from the Registry. Run RegEdit.
Source(s):
click start type regedit press enter
or
Use the registry editor and find the key:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevic...
F: as in whatever drive you want to change, and then just change F: to G:
or
If the installation is being run from a network location or if the installation is being run from a directory structure that is several levels deep
(resulting in having too many characters in the path name), this error may occur.
Follow these steps to fix this error:
Copy all the installation files (setup.exe and all other files in the same directory) from the network location or source media (such as the CD) by pressing Ctrl + A or Edit > Select All.
Create a folder on your local hard drive (e.g., Desktop) by right-clicking and selecting New > Folder.
Paste (Ctrl + V) the installation files into the folder.
Double-click setup.exe to run the installation locally.
If the scenarios above are not related to or did not resolve this issue, the error might be caused by something specific to your computer.
The following general troubleshooting tips might help resolve the issue:
Clean the Temp Directory
Install ikernel
Hope this helps.
Nov 26, 2012 | Seagate Computers & Internet
How to fix parameter incorrect
or
Source(s):
or
or
Install ikernel
hope this helps
Sep 17, 2012 | Seagate Freeagent Goflex 500 GB USB 2.0...
My vaio laptop with windows XP will not "see" an
Hi mpetersen809,
When you connect your external hard drive, does Windows chime or show an "installing devices" pop-up in the lower right corner of your screen? If this occurs, but you can't see the drive under "My Computer," your external drive might be trying to use a drive letter that's already in use by another device. To resolve this issue, you can manually set the drive letter for your external drive:
  1. Right-click My Computer and choose "Manage." A "Computer Management" window will appear.
  2. In the right pane, under "Storage," click "Disk Management."
  3. Locate your external drive at the bottom of the right pane. Disk 0 is your laptop's internal hard drive, so your external drive will probably be named "Disk 1" or "Disk 2."
  4. Right-click the area of the drive that says "Healthy (Primary Partition)" and select "Change drive letter and paths."
  5. Click the "Change" button, then select an unused drive letter (like Y or Q) from the drop-down menu and click "OK."
  6. Click "Yes" to confirm that you want to change the drive letter.
  7. Close the Computer Management window, then open My Computer to see whether your external drive is visible.
If this doesn't work, there could be a problem with the external drive. Test the drive by plugging it into another computer. If the drive isn't recognized on the second computer, contact Iomega for warranty support or replace the drive.
May 17, 2011 | Computers & Internet
My SimpleDrive 320 is being recognized as "storage" with no drive letter designation. Ideas?
Connect harddrive to computer then when you power up the computer press F8 key 5 to 6 times then enter in safe mode then if still letter will not assigned then follow below.First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Apr 11, 2011 | SimpleTech 320GB SimpleDrive External by...
I cannot get my pc to recognize my external hard drive. It has in the past, before I formatted it. I hear a sound when it is connected but no drive letter or icon.
Jan 10, 2011 | Iomega 34579 1 TB USB 20 Hard Drive
The WD my passport is not recognized by the computer .. It was wroking fine couple of weeks ago and am pretty sure it didn't fall or something.. its not recognized and not showing on my computer .. please...
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Dec 31, 2010 | Western Digital My Passport Essential...
My book essential has worked for several months now til now.... the white light is just blinking and my computer doesntg seem to recognize it anymore what should i do?
From the user manual (click here) on page 4, the slow blinking means that the drive is in standby mode.
The user manual does not explain how to get the drive out of standby mode, but you may want to try the procedure for powering off the drive that is on page 34 that say to press the power button on the back of the unit and wait for the LEDs to turn off.
If the unit does not power-off on its own within a few minutes of pressing the power button, the next thing to do is the following:
Shut down your computer with the drive still connected and powered-up. Once the computer is completely powered-down (no lights on or noise coming from the computer, unplug the power cord of the external USB hard drive and wait a minute. After you've waited a minute with the external USB hard drive unplugged from power, plug the power cord back in to the external USB hard drive Make sure the USB cable from the drive to the computer is properly connected. Power-up your computer using the power button on the computer and let the computer boot as usual. Once the computer has booted, check whether the external USB hard drive is now available.
Happy New Year and Thanks for using FixYa
Dec 31, 2010 | Western Digital My Book Essential 1TB...
External Hard Drive Not Regonized
I can help you with this. Follow these instructions--> Start-->Control Panel-->Administrative Tools-->Computer Management, under the Storage section select "Disk management". Locate the external harddrive, and then change the drive letter.
Select the external drive. Right click, and select "Change drive letters and paths"-->Highlight the driveletter to change-->Click the "Change" button-->From the drop-down list choose an unused drive letter, and hit Ok.
The external drive should be recognized and accessible at this point. Let me know if you have any other questions.
Thank You, Raph30
Jan 28, 2009 | Western Digital 250GB MyBook External USB...
Installing maps
You might have a problem with the disk. Take the disks back to place of purchase and ask for a replacement set, or else phone Garmin and explain you think you have a bad disk.
Oct 11, 2008 | Garmin eTrex Legend GPS Receiver
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Fantom Titanium Hard Drive Logo
217 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
