No volume without holding remote button
26'' Westinghouse SK26H730S volume stays off. You can raise it with the remote but as soon as you take your finger off the button it goes back down to zero.
  • 325 Answers
The volume on either on your Remote or Tv is stuck down. This can be caused by spilling Liquid onto the remote (we all do it) you can test which one it is.
take the battery's out of the remote and turn the volume up via the Tv volume button on the telly. If this stays at the required Volume Then this means that the - volume button is stuck down on the remote. Try and clean it with something like a baby wipe or something similar (not a sopping wet cloth) If this does not work then you may need a new remote.
Hope this Helps
Cheers
Little Dish Fitter
Posted on Sep 24, 2009
Westinghouse Setup wizard
westinghouse will not work with an APPLE remote
Jun 09, 2013 | Westinghouse Televison & Video
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
Hello! I wanted to give you a few more codes that you may not have tried. I also wanted to give you the instructions to the power scan, which will scan the TV for the correct code. I hoep this helps!
Codes:
500
795
719
Power Scan:
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Becki Barned
DISH Network Customer Service
I have dish network and need the remote code from the tv to activate the dish remote to change the channels, etc. And how do i program the remote to work with the tv
Hello! My name is Becki Barned with DISH Network. To program your remote, just follow these simple steps:
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
500
795
816
Becki Barned
Apr 06, 2011 | Westinghouse 26" LCD Flat-Panel HDTV
I can get my dishnetwork remote to program for the volume nor to turn it on or off help me please the model #w32001
We would be happy to help you with that.
Step 1:
Press and hold the TV button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to your Westinghouse TV. Potential codes for White Westinghouse are: 500, 719, 664, 555, 674, 659, 670, 672, 641 and 573. Then press the pound (#) button. If the code entered is valid for the remote, the mode light flashes three times. Your DISH Network remote should be able to control your TV. Thanks for being a valued DISH Network customer.
Phillip Chang
DISH Network Customer Service Representative
Jan 20, 2011 | Westinghouse W32001 20 in. HD-Ready LCD...
What is the correct wall mount for this tv? and cheapest too! westinghouse sk26H730S tv (26 inch lcd tv)
You dont need a correct one you just need one wall mount that can fit 26 - 30 inch search wall mount on trademe or ebay realy cheap and they can ship it down to you thats the cheapest way
Aug 01, 2009 | Westinghouse Electric SK-26H730S 26 in....
Westinghouse lcd 26" has blue screen and no sound
1. plug it into a input device (well duuh)
2. it could be a fried mother board or a cracked one !!
3. it could be the sound plate a gt674jj49329710hfwllw plate u need u probably have a gt683jj63835540gdhdys plate !!
4. take it back !!
Jan 03, 2009 | Westinghouse SK-26H520S 26 in. LCD HDTV
SONY KP 51WS500 - Volume & Menu won't stay on
This would be weird for a sony but it sounds like the volume down button on the front of the set is stuck...very very uncommon for a sony. Try taking the bottom front cover off the set and unpluging the button assyembly then see if the remote works the set with it unpluged.
Tim nolan
Sep 17, 2008 | Sony KP-51WS500 51" Rear Projection...
Lcd screen does not stay on.
Not really a solution, but a workaround. You can enter public mode menu and disable power off by power button. Hold the remote in one hand (you'll need it later), and with the other hand maintain "volume " and "input" buttons on the TV, and press the power button. Maintain the power button depressed otherwise the TV will power off. You can release the other buttons. The TV should display a "Public mode" dialog box where you can input a 3-digit password. Enter "027" with the remote. The TV should display the public mode menu. It is operated with the cursor arrows of the remote. Highlight the "power on fixed" item. Change it to "fixed". Then highlight "execute" and press OK on the remote. You should now be able to release the power button without turning off the TV.
In Sharp's own words :
In "Fixed" setting, the power-off by the power key of the unit is invalidated and the image is kept being received. The power can be turned off by stopping the power supply from AC.
Note that you won't be able to turn the TV off with the remote either.
Also, if you wish to enter public mode menu again, you will have to disconnect and reconnect the power cord on the back of the TV while maintaining "volume " and "input" buttons depressed, because the power button is no longer operating.
Nov 27, 2007 | Televison & Video
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
