Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Hi friend, SC542 Error Code Means =( Fuser Temperature warm up error, HOT ROLLER WARM UP ERROR) Did you change the Thermofuse, if you did used a volt meter check for
continuity accross the fuser lamp could be a source of the problem. If the problem still persists then look for local support.
I have a 2004 konica-minolta bizhub C350. It was asking us to change the overflow bottle for ...
(More)
I have a 2004 konica-minolta bizhub C350. It was asking us to change the overflow bottle for awhile, so we didn't use it for months until,we did. When we tried to use it after that, it gave us the code C0510. We have had the fuser replaced last year. Before we shut it down the last time, it had stopped folding and stapling properly.
how do I print (not copy) a test page from my sharp arm160 copier to see that I dont have a scratch...
(More)
how do I print (not copy) a test page from my sharp arm160 copier to see that I dont have a scratch on my glass?
