Question about Zenith L30W36 30 in. LCD Television
What price is lcd moniter
What price is 20" lcd moniter
    President:
  • 1,187 Answers
Check frys.com or BestBuy.com pricing.
20" LCD start at around $120 to $200.
Some (not just the higher-cost ones) have features like built-in speakers, USB hubs, height adjustment, screen rotation, etc.).
IMHO, Height adjustment is the most important "extra" (really).
2D/3D LCD's are on clearence ($199) everywhere (newer -expensive- technology coming soon)
Posted on Sep 24, 2009
My dell moniter 2010f flickers all the time. I have another moniter on that uses the same card by does'n flickers. I also pugged the dell in by its self and it still flickered. l also down loaded...
Sounds like an issue with the backlight in the monitor. Usually the backlight is built in to the LCD panel so there really isn't a way of fixing this unless you replace the panel.
Please rate my solution to show your appreciation!
Jun 02, 2011 | Dell ST2010 20 inch LCD Monitor
Moniter goes into sleep mode after i turn it on. Have to turn off the monitor for 20 seconds and then it comes back on for about 20 seconds and goes back into sleep mode
This may be a problem with the monitor, such as a failing video board, or it may also be a problem with the video card in your computer. If you can try the monitor on another computer or try a different monitor on your computer, you will have the answer. At the price new 18" widescreens are selling for (sub 100.00 in Canada), I would have a hard time justifying spending too much time or money trying to fix this one.
Mar 09, 2011 | HP Pavilion F1703 17" LCD Monitor
Hello sir i have a broblm in my samsung synicmastr 19" blak, when i switch on the moniter, the moniter is with in 2 or 3 second automitically off the display light but moniter is still on and display...
this problem can occur cause of two cases 1 problem with LCD panel (replacement can solve) 2 power failure in side moniter (repairing moniter can solve)
thanx PLZ vote
Feb 22, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
My moniter is not working at all, is it posibel
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 10, 2010 | Apple Cinema 20" LCD Monitor
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Monitor does not fit on post
I bought a Samsung 24inch LCD moniter I had a hard time putting it on its stand. It will work you just have to put a lot of pressure on it but do so very carefully.
Aug 21, 2009 | Samsung 204T 20" LCD Monitor
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
15.6 lcd wide moniter (low light)
It's LCD pannel problem
Remove the LCD pannel and checket flowrocent tubes at top of LCD Screen and Bottom of LCD Pannel. If U Find any burning area at end of F tube, please clean it and solder the flowercent tubes in same possion and connect as same.
Oct 03, 2008 | Acer AL2216WBD LCD Monitor
NEW EMERSON 20" LCD STERO TV/DVD- NOT WORKING
the flash was the fuse inside the set blowing it usually takes out one or two diodes in the power supply section but maybeyou got lucky and its only the fuse.
Mar 10, 2008 | Emerson EWL20D6 Television
Moniter Vga cable
You need a vga to dvi cable, your local PC shop should be able to help.
Oct 06, 2007 | Gateway FPD2275W LCD Monitor
Zenith L30W36 30 in. LCD Television Logo
41 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
