Question about Samsung CLP-510N Laser Printer
Keeps telling us black toner out of ink, and it is not...have replaced with a new cartridge.
    President:
  • 2,306 Answers
If it's a generic cartridge, it probably won't work, if it's samsung you need to clean the little metal contacts on the cartridge and inside the printer.
Posted on Sep 24, 2009
Seal tape from toner cartridge tore
prining invoices to letterhead, your laser printer is an integral part of your company's computer system. The device's ink is stored in one or more toner cartridges that are replaceable - a single black cartridge, if you have a laser printer that only prints black, or three color cartridges along with a black cartridge if the laser printer prints both color and black. The cartridges are available at office supply, retail and warehouse stores. Like inkjet cartridges, toner cartridges contain a strip of sealing tape that keeps the powder ink from spilling out until you are ready to install the cartridge.
Sponsored Link
Computer AMC ServicesOnlinepcshop.in
Laptop-PC Repairs in Delhi NCR. Total PC Solutions. Get Free Quotes
1Remove the toner cartridge from its packaging, if the cartridge is still in its box, and shake the cartridge from side to side to evenly distribute its toner.
2Hold the cartridge away from your body so ink won't spill onto your clothes or shoes. Grab the cartridge's sealing tape on the side of the cartridge and pull the tape firmly away from the cartridge. The sealing tape contains a plastic end piece for grasping it, usually in a different color than the toner cartridge.
3Continue pulling the sealing tape until it is completely out of the cartridge. Place the cartridge close to your printer or on a surface nearby until you are ready to install it. Dispose of the sealing tape in a trashcan or bag; try not to get any toner present on the tape on your hands or clothing.
Sep 14, 2013 | Xerox WorkCentre 4150 Black and White...
An unsupported black toner cartridge is installed
Some replacement cartridges require a new "chip" be installed to tell the printer that the cartridge is a match. I would check with New Egg and see if they forgot to send the chips, if required. I don't know of a manual bypass to the system.
Dave W.
Sep 14, 2012 | Xerox Phaser 6100/DN Laser Printer
Hi i cannot print any documents ive typed with words or school information it keeps saying STATUS:TONER LOW ??
Based upon your question, which is a bit vague, you must have a laser printer. What the printer is telling you is it has insufficient toner (some incorrectly mis-state "toner" with "ink". Laser printer = Toner. Inkjet printer = ink) for the print job to occur. If you have a laser printer which prints in only black (black and white), then you can try this:
Black only: Open the toner access panel on your printer, remove the toner cartridge (it will easily pull out), and GENTLY shake the toner cartridge from side-to-side . What you're doing is allowing toner (ink?? It's more of a powder-like substance which consists of ground-up plastic) to shake evenly to the bottom of the cartridge. Then, put it back in. IMPORTANT: This will not work for long. You need to get a new toner cartridge soon!
Color: If you have a laser printer which can print in color (based upon your description, it sounds like this is NOT the case. If you have a color laser printer, it would display to you that a particular color is out of toner), then do the same thing as described above... but for EACH toner cartridge.
It still doesn't work: If this does not work, then you're out of toner (Ink... sigh). You MUST replace your toner cartridge which is out of toner. If there was another way to do it, I would tell you. When you're out, you're out.
Please let me know if you have any further questions by doing a REPLY to this answer. I'll be happy to help!
Oct 01, 2011 | Office Equipment & Supplies
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Black ink
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 21, 2010 | Lexmark X5150 All-In-One InkJet Printer
HP officejet pro 8500 ink cartridge problem
Changing a printer cartridge is not complex but improper handling of the parts may damage the printer and the cartridge. If the user notices that while printing the ink comes out dry or faded, it may be time to change the ink or the toner. The user will know if it is time to change the toner because instead of a sharp image, one will get a faded image. It is time to change the ink cartridge when the printing comes out spotty or colors are used to replace others —for instance, blue for black or yellow for red. Remember, faded images signal the need to change the toner; spotty printing signals the need to change the ink cartridge get more help for change cartridge .
Hope this helps you.
Jan 21, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
Black Toner replaced
Replace Toner with gen cartridge.
Or Take cartridge back as faulty after checking that it was opened and installed correctly.
Check display on printer for indications that maybe it needs one of the 3 colour toners indicators are Y,C or M
K is black
Oct 20, 2007 | Epson Aculaser C1100 Printer
Samsung CLP-510N Laser Printer Logo
85 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
