Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Drive Being Recognized as Removable Disk
I've had this drive for a couple of weeks and it had worked fine. I (gently) moved the drive and the computer to a different location in the house. All of a sudden the drive is only being recognized as "Sunplus USB2SATA Bridge Device" which is a removable disk. I can't access any data. This happens when the drive is connected to a desktop computer running XP and a laptop running Vista. Is there any fix or is the data lost?
  • 4 more comments
  • rokketz Dec 17, 2007
    Thanks, but I'd tried that many, many, many times already before I posted here in desperation.
  • Dragondeath Mar 05, 2008
    I am having the same problem, but I have a brand new 1TB HDD, and I have a vista laptop.
  • Anonymous Jul 09, 2008
    Me too
  • Anonymous Jul 19, 2008
    Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty I took it apart and found this to be the exact case.
    ! ! ! ! Please perform this at your own risk ! ! ! ! Especially if you warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
  • aijiqpay Aug 11, 2008
    I have the same problem. But realised that if you connect your portable hard drive to the back USB ports, all works well. Computer reads it as hard drive.
    It only reads it as the SATA thingy if you connect at the front USB Ports.
    Not sure why and how to solve this issue. Perhaps the back USB ports are more "authentic" in a sense that it is connected to motherboard directly
  • Anonymous Aug 30, 2008
    same problem with TOSHIBA PX1349e-3g50 / 500GB USB 2.0
    kanker kanker kanker
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Posted on Jul 19, 2008
  • 119 Answers
You can go to the device manager, remove the sunplus from it, and reconnect your harddrive, then it should download the right drivers
Posted on Dec 16, 2007
Tried this solution and it does not work for me. thanks for the help though.
Posted on Apr 13, 2008
My hard drive 500gb fell from 3 feet stopped working i tried everything nothing worked so i banged it once while the light was blue and connected to my pc suddenly light turned red and got recognized. it was placed flat down blue light and the bottom right side when i picked it up to put it side ways it stoped working so i suggest try placing it with blue light at the bottom right side hope this helps
Posted on Mar 23, 2010
HPv165w recognized in Device manager...But cant open it in My computer..
Try inserting the pen drive into another computer to see if you can open the data on this pen drive.
If not you may need to format the pen drive.
Nov 24, 2012 | Electronics - Others
Hard drive has been working fine but I needed a larger capacity one. So I moved everything that was on this HD to the new 1 terabyte drive EXCEPT my iTunes because I knew it would take a long time. When I...
What I would do is unplug it Immediatly and stop using it so you won't screw it up any more. On a side note Apple is reported to be giving you unlimited dowloads of your music so that may save you. If it's not being recognized try going onto a different computer.
Mar 07, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
The WD my passport is not recognized by the computer .. It was wroking fine couple of weeks ago and am pretty sure it didn't fall or something.. its not recognized and not showing on my computer .. please...
Assign a drive letter for the External drive.
  • Right Click on My Computer
  • Scroll to Manage
  • Select Disk Management
  • Locate the External drive in the lower bottom Right corner, Right Click, Select Assign Drive Letter. Ok/Close
Open up My Computer, and you should see your External drive with your new drive letter assigned to it.
Dec 31, 2010 | Western Digital My Passport Essential...
My hard drive has stopped being recognised by my computer! Please help! One day it was working fine and then the next it just completely stopped being recognised by the computer. I have tried the drive in...
that really happens when hardisk crashed..
there is nothing to do but replace it.
but wait.. I have experience that also, could not retrieve all my files in my drive. So what I did is hide it in my stock room for a couple of weeks.
Then one day when i am about to throw away the drive,I get this crazy ideas to try my hardisk again as back up drive.
I connected my drive, put the jumper in it as slave and open my computer.
At first, it reads very slowly after booting, hardly recognized the disk, but it did...
when I am in windows and started browsing the disk, it would take it some time before loading all the files.
When that happened I back up those files and save that to my master drive.
Don't lose hope It might happen to you..
I think what happen is when I hide the disk for a couple of weeks the disk itself discharge all the left volts in it.. not sure about that.
May 19, 2010 | Iomega Black Series USB 2.0 & FireWire...
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
I want to move pictures from sanddisk from phone onto computer.
Connect your scandisk to computer with usb cable usb port.
Then your computer recognized it as removable storage.
Open my computer then open removable disk then copy pictures and paste in to computer's any drive.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 13, 2009 | SanDisk 2GB microSD Memory Card
My computer will not find removable hard drive
driver may have corrupted try to format it... may be the issue then get resolved .... xee.
Sep 24, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Sandisk doesn't recognized in computer
First connect your memory stic to other computer if it works there thne it has not any issue.
Then connect in your computer on which not recognized .
Then opem my computer if you can't see any removable storage then right click on my computer then go to its proeprty then hardware then device manager.
Then uninstall all usb drivers then restart computer then check .
If still face same issue then right click on my computer then click on manage thne go to disk management.then removable media/
check there if you find removable storage then right click on it then open or explore it.
if you still not recognized then when you power up the computer press F1 or F2 or "del' key to enter in BIOS.
Then go to advanced in bios then set LEGACY 2.0 enabled. then save settings and exit.
then check.
Aslo check your computer usb ports are working fine.
Let me know if you need more assistanse.
Thanks.
Aug 28, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
Use EASEUS Data Recovery Wizard to recover the data. You can find the program on the internet..
To format afterwards click Start, click Run and type compmgmt.msc.. In there format your drive..
Mar 10, 2009 | Trekstor DataStation maxi m.u SATA 3.5"...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
5,566 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
