Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
PC was rebooting itself. I tried vacuuming out dust from inside box. Now it won't boot up at all. Numbers on front panel 3 & 4 stay lit and monitor only shows scrambled colours PC is a DELL Dimension 5150
  • Stu Morris K May 11, 2010
    sorry to hear your problem but using a hoover is not a good idea near a pc ,the hoover generates a static charge you could have blown something on the pc does your pc have a graphics card that you can remove from the motherboard
    Scholar:
  • 138 Answers
Try manual cleaning the graphics card and the RAM by removing from the slot and rub the pins with pencil eraser as shown in the images.
And re-attach them to the motherboard, also clean the graphics card's fan with small paint brush. Works for me, hope same goes with you.
Posted on Sep 24, 2009
Error light code 3 & 4 in front panels
Hi Carlos, error code 3 & 4 is caused by faulty RAM (Memory modules) installed in the PC. You could try the following to resolve the issue:
1. Open up the computer cover
2. Locate the memory module(s)
3. Remove them memory module(s)
4. Use a can of compressed air or spray contact cleaner onto the center of the DIMM connectors to clean all the contacts. Do NOT use a normal brush to clear dust away. Wait for 5minutes for the contact cleaner to dry.
5. Reseat the memory module(s)
6. Turn on the computer and check if codes 3 & 4 still light up. If it does not, it should boot into the Operating System.
7. If codes 3 & 4 continues to light up, you will need to run a memory diagnostic test to determine which of the memory module is faulty.
Sep 07, 2016 | Dell OPTIPLEX 960 MT Desktop Computer...
Lenovo a310 screen won't boot up and turn on
This could be a case of overheating.
First question, did the no signals sign appear out of the blue?
Check inside for melted components.
Clean your computer, remove all dust.
Check back with me.
Oct 22, 2012 | Lenovo Computers & Internet
Numbers 3and 4 are lit on front of dell 755 nothing else comes on but fan
I was going to suggest that you have bad sectors on your hard drive that prevent you from booting, but since it won't boot from a CD either it sounds like you have a problem with your BIOS and possibly bad sectors on the HD as well. There's no simple way to fix this if that's the case, so it's best to be left up to a local pc repairman in your area...sorry
Aug 27, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Computer will not boot numbers on fron of computer
the lights denote that is has encountered a system failure, very vague to be exact. try running the hard drive diagnostic if possible. it could also mean a hardware problem, worst case scenario would be a mobo failure..
Hope it helps!
Feb 14, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Gateway GT4010 PC keeps rebooting itself before
Try replacing the hard drive cable. If that doesn't fix the problem, then you may have bad RAM, bad motherboard or a bad power supply. Sounds like a hardware issue and not software. try booting your computer in safe mode since it doesn't load all the device drivers. If it still reboots then you'll have to keep swapping parts and booting up the computer to isolate the problem.
Oct 06, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Ink cartridge full but won´t print
This might need to be reset.
Here' how...just follow the instructions..
moz-screenshot.pngThere's two ways to reset it
First: Soft Reset
1. Open front cover.
2. Hold down button located under LED's until all LED's are lit.
3. Release button and make sure drum LED is off, then
4. Close cover
Second: Factory Reset
1. Turn the printer off.
2. Hold in the circular button on the front panel of the printer.
3. Turn the printer back on.
4. When the DRUM light is lit by itself let go of the button.
5. Hold in the circular button on the front panel again.
6. Once the Alarm light comes on, let go of the button.
This will perform a factory reset on the printer.
I hope that's everything you want.
Please accept this answer if this will help you.
Thank you for using Fixya.
Oct 02, 2009 | Brother HL 1440 Laser Printer
Dell Dimension 2350 reboots every 3 secs
Could be a couple of things.
Disconnect the C drive and see if the computer will stay turned on. If it does (you'll get an operating system not found error), then reconnect the c drive and see if you can get into the BIOS. If not, you'll need to replace the hard drive.
Could also be a faulty power supply. As soon as it tries to boot off the hard drive, it puts too much strain on the PS and causes a reboot.
Finally, if neither of those fix the issue, then the problem is motherboard and at that point it is more cost effective to replace the computer unless you can find a cheap, used motherboard. Good luck!
Jul 05, 2009 | Dell Computers & Internet
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Reboots itself within minutes
I think that if you can boot up in safe mode you can slow things down enough to do something. If you can get there, you can stop the rebooting by going into "Control Panel", click on "System", click on the "Advanced" tab, click on the "Settings" box and uncheck the "Automatically Restart" box.
Then you can go in to "Add or remove programs". If you remove the AOL program, you'll probably be good!
Please let me know how this works for you.
Ron-
Nov 26, 2007 | IBM NetVista A40i (2251VAU) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
267 people viewed this question
Alun Cox
