Question about Indesit 24 in. DE73 Evolution Free-standing Dishwasher
RO2 Fault The washer gets stuck in the washing cycle with RO2 fault flashing.  Filters are clean, both inlet and outlet pipes are free and no blockage anywhere. The above error is getting more frequent.
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
  • 5 Answers
SOURCE: di67 s dishwasher
Try tilting your dishwasher forwards. Be warned that water will escape from the front. I have had this problem and paid an engineer to come and tell me this. If your machine is not completely level water collects at the front and does not empty. This then causes the machine not to work. Good Luck
Posted on Jan 15, 2008
  • 105 Answers
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Posted on Feb 24, 2008
  • 75 Answers
SOURCE: Dyson DC08
So much for never losing suction, huh?? Try the reset button.
Posted on Feb 29, 2008
SOURCE: Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
i have a whirlpool 6th sense washing machine, it has come up with a red light saying clean pump, does anyone know where the pump is please, ive lost my handbook!!
Posted on Mar 14, 2008
Fault F05 flashing
First of all remove the hose and drain off water then open the door . Once the drain pump outlet filters and the inlet filters are checked, check for free flow. If the cycle does not start check for power output from the controller on pump and motor. If not the board is a suspect.
Jan 23, 2013 | Washing Machines
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Hoover nextra washer was showing fault code 3. on inspection i found a ten pence piece in the in hard plastic pipe of the pump. removed blockage and set it to cycle. machine was showing fault code 1. i...
Hoover Nextra fault code 1 actually decodes as 'door interlock/door switch' (???!!)
Fault code 2 states' fill time-out or solenoid valve etc'
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 19, 2011 | Hoover Washing Machines
The machine is indicating an IE fault
An IE error code will appear if the washer has not filled with water in approximately 8 minutes. If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle. There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly wm_inlet_filter_removal(1).jpg
Mar 02, 2011 | LG WD-1280FHD Front Load Washer
I have a Zanussi 1600 Jet System Washing Machine, it has started the cycle and 4 mins into it, an E10 error reads on the display, have turned the machine off, and back on, checked pipes, can see you...
This error code relates to water pressure check that the pipes are not kinked,check the water valves are fully on also check if the little filters in the end of the hoses are cleaned.Make sure that the mains water pressure has not been reduced.There could still be a fault with one of the inlet valves but it is most probably the little gauze filters
Apr 26, 2010 | Zanussi IZ161S Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Oct 01, 2007 | Hotpoint Aquarius WD63 Front Load...
Flashing Active Light and not taking fabric conditioner
1: The flashing wash light usually indicates a problem with the door latch while a flashing rinse/spin light usually indicates a problem with your inlet valve. 2: The cold water inlet has 2 independant outlets. The issue that you are describing indicates that one part of the cold water inlet is not opening to allow water to flow to the proper dispenser port.
Mar 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Indesit 24 in. DE73 Evolution Free-standing Dishwasher Logo
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
