Question about Whirlpool Dryers
Ink stains vin my frontload gas dryer
An ink pen exploded in my frontend kitchen aid gas dryer suggestions to remove the ink stains?
Spray hairspray onto cotton and wipe off. Then wipe out the hairspray with a clean damp cloth before drying again.
Posted on Sep 24, 2009
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
Ink - pen went through the dryer and stained it badly how do I get the stain out of the dryer?
Run a couple cycles with C.L.R in it and some old towels or rags
Jan 20, 2011 | Dryers
Somehow a ball point pen went into the dryer. I now have ink on the inside of the drum. What can I do to get the ink off the drum. It should be noted that the dryer weny through a complete cycle before...
You may have to experiment with solvents to find one that will remove the bulk of the ink. Start with rubbing alcohol, then try a mineral spirits (paint thinner) or WD-40 oil, and finally some acetone. Make sure there are no sparks or fire nearby while using these solvents. Be sure to clean the areas with a spray cleaner after any success to remove a lingering smell. You may have some permanent stain left that will just have to wear off, but shouldn't affect your clothes. Hope this helps!
Dec 11, 2010 | Whirlpool Dryers
Hello,i was washing my cloths the other night and a pen happened to be one of my pockets. The pen didn't explode in the washer but it did in the dryer. It ruined some of my cloths which is no big deal.The...
Hairspray is an excellent solution to the ballpoint pen ink problem. Buy the cheapest you can find and spray, let the spray sit on the spots for a few seconds and wipe with a paper towel. Keep doing this until the spot is removed. This also works on fabrics as well. As a former teacher, my red grading pen ruined several of my white shirts. I used my husband's $1.29 can of hairspray and saved over $100 in garments. He was pretty angry about my using all his hairspray but when I pointed out the money saved by not having to purchase new blouses, he relented. I keep a can of hairspray in my laundry room at all times.
Nov 04, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Pen ink stains on dryer drum, help!
use liquid solvent...thinners or maybe even some petrol from the lawn mower.... a little on a rag should do the trick,maybe some metho or even turps.
Jul 20, 2010 | Kenmore Elite HE4 Electric Dryer
Stain in dryer
This will work. Soak white towel or other white fabric in bleach water, then slightly wring them out, leaving very wet. Then put them in dryer, on low or fluff cycle. Run for 60 minutes or more. This should rub off all the ink in the dryer. You may have to repeat if you have alot of ink. I have done this a few times and it has always work, good luck.
Dan
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
I forgot to empty pocket. a ball point pen exploded and i have ink all over the inside of my dryer. I have not found anything to remove it. Any suggestions?
Try aerosol hair spray. It removes dried ink from clothes, may also work for your dryer. If not, try paint thinner or mineral spirits, available at any hardware store.
Aug 11, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ink in the dryer
Rubbing alcohol will work to remove most of it if you use alot of elbow grease.
What I found worked the best and quickest was a Mr Clean Magic Eraser wetted acetone nail polish remover. Leave the dryer door open to let it air dry, then put a couple of white towels soaked in bleach water and run the dryer on a non-heat cycle to remove any remaining smudges.
To be paranoid, I then ran the same towels through the washer and dryed them on high heat to make sure there was no ink I missed that might ruin any further clothes.
Mar 28, 2008 | Roper REX4634KQ Electric Dryer
Ink in Dryer
wet towel add about 1/2 cup of bleach, put in dryer.... the ink completely gone in less than 10 minutes
Sep 28, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Dryers Logo
142 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
