Question about Kenmore 46462 Front Load Washer
Kenmore front loader object stuck under drum
I have a kenmore front loader HE2 type 831. There's a lighter caught between the silver tub that spins and the outer area below the flexible plastic lip. I can not pull the lighter out in the direction it neds to be to fit thru the small crack. How can I cees this area?
  • 909 Answers
Sugest you remove the heating element and use a torch to see item through hole then pull out in the best manor possible.
Posted on Sep 24, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Can I remove the front part of the tub from the drum if I support the drum?
sorry but what model, My brother in law did something similar with a Kenmore, left tub in place to replace a slip roller in the front.
my clinker was stuck under a fin inside the tub
May 18, 2015 | LG Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore front loader does not go into the spin cyclr and water is left in the drum
Most likely either the drain pump or hose is clogged or perhaps the drain pump is not working. Machine will not spin with water still in the drum.. Check all connections.
Mar 12, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2Plus washer. It sounds like a pin or other metal object may have fallen through the holes of the drum. You can hear it roll around when you spin the drum. Is there any way to remove it without...
Overfilling loads can cause small objects like pins, coins, and small socks to get between the tub abd Basket of your washer.
The basket is held onto the rear half of the outer tub simply by the bolt to the main pulley.
Remove the bolt, remove the pulley, and the basket shaft should slip right out of the bearings of
the rear tub.
Simply shining a light around between the basket and outer tub should confirm that there is something in there, since you have access to do this with
the front tub removed. Go ahead, remove the pulley and bolt, and if
the basket comes out, then check everything out.
If it doesn't, don't try pounding it out; stop there and go to plan B, which is a new basket
and tub assembly.
Front - loader: Remove Bellow
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2010 | Kenmore HE2 Plus Front Load Washer
Loud noise during spin cycle... maybe a bearing or belt.... no problems during wash cycle
First of all check there is no coin or similar object stuck between the barrel and outer drum. or could be possible object in pump. If you take a look at back of drum (presuming it's a front loader) Look for any water at bottom f drum, this could indicate water seal bearing trouble. If it is the latter then dont just replace water seal, replace the bearings as well. A set of bearings and water seal will cost around £50/£75 and should take a few hours to do.
Aug 24, 2009 | Kenmore HE2 Plus Front Load Washer
An object is caught behind the drum of our Kenmore
remove the back and check if large pulley is wobbely on shaft. common problem. replace pulley.
Jun 12, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 46462 Front Load Washer Logo
144 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
