Question about Lexmark Wireless X4850 All-In-One Inkjet Printer
Lexmark x4850 will not communicate with computer
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a ''successful'' installation. I can't get it to print anything now. It will not even print a test page. I now get a message, “problem communicating with the printer.” I uninstalled the software, rebooted, and reinstalled the software with the downloaded file, “cjb4800en.” Driver did not install even though I got a “printer installed successfully” message. There is no printer in Network/Printers and no printer listed in Device manager. Lexmark 4800 Series program shows in the Start menu. I ran the Wireless Configuration Utility, got another “successful” installation message with no results. I checked the pop-up screen on the printer under “Network Setup” and printed a Network Settings page. It says the printer is “Connected,” Mac Address is good, IP address is good, TCP/IP is all on and good. Wireless shows, “Infrastructure.” SSID is the same as the router. Quality says, “Good.” A Ping of the computer IP address and Gateway was successful. I uninstalled the software again, as well as every running program, including my firewall, anti-virus/anti-spyware and reinstalled the printer again using the disc that came with my printer. This time, the printer shows up in control panel/printers, but nothing shows up in the Device manager. My firewall shows the Printer communication system and Printer Device Monitor. I bought this printer from the Gazaro web site, but can’t find the purchase receipt. If I can’t get this thing running, I’m throwing it out the window and will never buy a Lexmark again! This is the third all-in-one wireless printer I’ve had with my current laptop and the only one I’ve had trouble with. I’m told it’s actually a Vista problem, but I don’t see how.
Trying to find the printer drive for a Lexmark X4850 that I can download to printer from an Acer Aspire laptop running Windows 8 64bit
The last operating system that supported that printer was VISTA. You can go to the lexmark site and download that driver and see if it will work with that computer. Even the HCL page for windows doesnt show any information on it and Lexmark says that printer is not in production any more.
Apr 14, 2014 | Lexmark Office Equipment & Supplies
My Lexmark x4850 has stopped prin?t the computer. What is wrongting . Sometimes it will print when I restar
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. After the install process, try to print a document again to verify that the problem is fixed.
Oct 23, 2011 | Lexmark Wireless X4850 All-In-One Inkjet...
How can I install my lexmark x4850 printer on a new computer without the installation CD?
You can download the Lexmark X4850 driver by visiting the Lexmark website at http://bit.ly/lY7NTO. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
May 30, 2011 | Lexmark X4270 All-In-One InkJet Printer
I own a x4850 printer and the drive is unsuccessfully installing on my DELL Windows 7 laptop, the printer is working fine w/ the netbook and laptop operating with Windows Vista. WHAT ARE MY OPTIONS?
Check if your Windows 7 is running on 32-bit or 64-bit operating system by going to Start menu > right click on Computer > Properties. Download the Lexmark X4850 driver for Windows 7 using this link: http://bit.ly/arNLm9(for 32-bit) or this link: http://bit.ly/abQkwd(for 64-bit). Execute the file to install the driver. Thank you for choosing Lexmark.
Sep 15, 2010 | Lexmark All-in-One Printer with PictBridge
Cannot use Lexmark X4850 printer without installation disc.
You should be able to go to the lexmark.com web site and search for your printer. Go to downloads and enter your printer description or X4850. This is the result I got. If your computer is running Windows, then you need to get either the download for 32 bit or 64 bit software. See microsoft.com link to tell the difference.
http://support.lexmark.com/index?locale=en&segment=DOWNLOAD&startover=y&userlocale=EN_US&question=X4850&productCode=LEXMARK_X4850&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X4850&searchid=1257295870088#2( Lexmark Link for Macintosh or Windows Driver Software)
http://support.microsoft.com/kb/827218 (To tell if your Windows Operating System is 32 or 64 bit)
Nov 03, 2009 | Lexmark X5470 All-In-One InkJet Printer
I am running Vista Home 32 bit and have a Lexmark X4850. It will not communicate with the printer from either wireless or USB. I got it to print a test page from both, but that was one time after a...
Have you talked with Lexmark Technical Support? I suspect you may have to escalate this beyond level one. Vista on Mac is likely to have issues that differ from other Vista environments.
Sep 24, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark X4850 wireless how to make it find the wireless network. I've had this printer working with my Vista laptop till recently; then I moved to another area, configured my new home network and Internet...
If the printer itself is wireless, it does not need to recognize your wireless computer network. Call Lexmark to walk you through proper installation. Lexmark's manuals are not adequate regarding setup, in my opinion.
May 07, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Jan 25, 2009 | Lexmark Wireless X4850 All-In-One Inkjet...
Lexmark Wireless X4850 All-In-One Inkjet Printer Logo
261 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
