Question about Waterway Supreme Hi Flo Pump Dual Speed 2 Hp
How to change the bearings on this pump?? 2 h p 48 fram pump. do not have mod #. thank you.t whines when running, but works well. the flow is strong. paul de
  • Kieran Ruppert May 11, 2010
    You don't replace bearings on a pump, you replace them on the motor. Depending on the brand of motor (probally Century Or A.O.Smith) But to do this you need a bearing puller a vice, snap ring pliers and a press, then it gets involved. If you find out the brand of motor write again and I hope I can walk you through it.
How to troubleshoot a high pitched whine in the right fron side of my Nissan Maxima 2004
Could be one of the belts slipping or worn out. Might even be the water pump bearing. Does the whine increase/decrease as you rev? Whine louder if you suddenly accelerate?
Dec 09, 2014 | 2004 Nissan Maxima
Whining power steering pump on 2001 bmw 740il
have you put a different type of power steering fluid?
in some instance, if they put a different type of fluid, the solution bubbles up and makes a whining noise when you use the car.
tnx 4 using fixya,
drcool
Oct 10, 2008 | 2000 BMW 7 Series
Engine makes whining sound
Take the belt off and spin all of the pulleys. the bad component should be obvious. high pitch whine is usually alternator bearing for the 98 3800 its timkin part# 100ccab or it can be the power steering pump(but the pitch will change as your steering if it is that) water pump, idler and tensioner pulleys(if you have to change either one, replace the tensioner itself). if you have the supercharged model there are a few parts that can whine( or the s/c is low on oil.)
Apr 15, 2012 | 1998 Buick Park Avenue
1995 Ford Ranger whines. Three mech's, fuel pump, carrier bearings, wheel bearings. Who is closest?
You need to post the symptoms of your problem. And let us tell you what we think. But for what its worth here I go. Electric fuel pumps howl or moan. Carrier bearings on make noise when vehicle is moving down the road and make a squalling noise when the bearing is going bad but may be interpreted as a whine. Wheel bearings near the same as carrier bearings but they usually grind. So my guess is alternator or pulley bearing since they whine.
Mar 04, 2011 | 1995 Ford Ranger Supercab
My engine has a knocking sound
i'm sorry! does the engine dipstick for the oil,is it full? has it been run low on oil lately? is the knocking sound like a real hard knocking,thumping with like deep base sound?if so,do not start it again. you may have a bad crankshaft bearing,or a bad crank,broken crank. if it's a tapping sound,that's different. it could be low oil pressure, just like the lower knocking,it may be bad oil pump.my advice is this, lower knock from oil pan where you drain the oil,do not start! upper,on top of the engine,just change oil 1st add a fram oil filter,if in cold weather recommend 5w30weight oil,in summer,30weight castrol with fram oil filter.is your oil light on? if not,then it'not low on oil,but CHECK your oil on dipstick,just to be sure thank you for choosing fixya.com
Jan 28, 2011 | 2000 Ford Expedition
I have a DREAMMAKER SPA (6 months old) with a 2 speed HYBRID PUMP. It has developed a high pitched whistle or whine when running. Is this a bearing? Could there be some stuff stuck in the impeller??
90% chance it is indeed the bearings. It is possible something could be stuck in the impeller causing noise, but not usually a high pitched whine. If you see water leaking, or calcium buildup where the pump meets the motor, then the shaft seal has failed and that is what's causing the bearing failure. Either way you'll need to replace the motor or have the bearings replaced. Look for a local pool pump repair shop (or some pool supply stores replace bearings as well). They should check the motor out for free and give you estimate to to repair/rebuild, or a price on a new motor if that's what you need/want. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 11, 2010 | Dream Maker Spas Dream Maker SpaDition...
Same problem: a high pitch whine after extended driving
Sounds like a dry/failing bearing or power steering pump noise. You first need to try to track down where the noise is originating, and the most likely place is at the front of the engine.
I would start by listening with the hood up while parked with the engine running and the noise present, and seeing if it is coming from there. If so, the most likely cause is something connected to the belt - e.g. AC compressor clutch, tensioner, power steering pump, or generator. Can also be caused by the belt just slipping (warn out belt, tensioner not working properly).
Mar 31, 2017 | 2001 Chevrolet Venture
1998 IZUZU TROOPER WHINE SOUND ABOVE NORMAL ENGINE SOUND
It might be that the car has not had the Isuzu factory soundproofing mod done around the gerbox cover - speak with you dealer.
Possibly the alternator bearings are going , an autoelectric shop can tell you .
Feb 22, 2009 | 1998 Isuzu Trooper
Waterway Supreme Hi Flo Pump Dual Speed 2 Hp Logo
150 people viewed this question
Top Waterway Garden Experts
Mike Raino
Level 1 Expert
john h
J.D. Browning
J.D. Browning
Are you a Waterway Garden Expert? Answer questions, earn points and help others
