Question about Dell Latitude D400 Notebook
Non powering hi,i plug his chager to the note book,the light of the chager off, i remove it the light on again after that the note book did not on again,he did not see chager too
  • 58 Answers
Hi! the motherboard is dead. if the ac adapter light turns off when plugged in and if you unplug it, it will turn on, then the problem is with the motherboard. It needs to be replaced. Call Dell Tech support if you still have warranty to have the motherboard replaced or else, you have to pay for the repair.
Hope this helps!
Karlox
Posted on Dec 20, 2007
Can a vehicle run with a non functioning ECM?
if the check engine lite doesn't work it most likely needs cluster removed and bulb replaced its blown. if the computer is bad it wont run. I wanna say that ecu fuse will clear code from computer but its not main power to it. I would start with the bulb that way you can get code.
Feb 18, 2015 | 1994 Toyota 4Runner
My laptop compaq presario v6000 does not switch on but the power light comes on when the chager is on. when i try to turn the computer on it just flick the light on then back off. can anyone yep me to
The DC pin on your laptop is bent/broken/loose. Look at where your power adapter plugs in on your laptop. Get a paper clip, bend it out to make a long paper clip and slightly push its tip on the pin inside your laptop. If the pin moves chances are either the DC pin needs to be soldered down or needs to be replaced. The part is usually cheap around $10 but the labor can cost more than $50.
http://www.chargerbuy.com/original-compaq-presario-v6000-ac-adapter-65w.html
Dec 16, 2012 | Computers & Internet
Hi I have aspire 3690 laptop i put chager plug in.. orange light comes up but i cnt turn on the laptop..every time i press on button.. the orange light goes off.. please help many thanks
Hi..
try make a hard reset first.
1- remove laptop battery and laptop charger
2- press and hold on/off botton arount 30second
3- turn on laptop without battery and see what resoult
if problems still same, it's most likely your cpu, vga or motherboard problems and need u make detail troubleshooting such as service provider doing.
regards
Apr 26, 2011 | Computers & Internet
I bought a non dell battery for my inspiron 6400 note book but it wont charge,looking for a solutions,dell batteries too expensive john dublin ireland
the laptop will work with just adaptor plugged in and the battery removed.Try only adaptor plugged in.
Hoping this will work
thanks
Jan 05, 2011 | Dell Inspiron 6400 Notebook
Will not power on once chager is plugged in lights flash three times but there is nothing
what lights flashed? is it the LED locks or the battery light? try to run PSa. press andhold the fn key and pree the power button and release button at the same time when you see the dell logo screen
Oct 01, 2009 | Dell Inspiron 1000 Notebook
DELL Latitude D505
Have you tried the other fix? It often times works.
Remove the battery AND the power cord.
Hold the power button for 10 seconds.
Now plug in the power cord.
Magic should happen
Feb 27, 2009 | Dell Latitude D505 Notebook
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
It is a dell cpx lapetop. Will not start up.
change the power jack of the laptop..because the sounds like the ac power is not working in laptop..
Jan 04, 2009 | Dell Latitude CPX Notebook
C 400 Latitude display problem
That LOCK A sysmbol is the caps lock.
Most likely its due to hardware failure. Be sure the battery is holding a charge and the power adapter is working.
It could be bad Ram. Usually when there is nothing at all but a quick light on and off and nothing, its due to motherboard issues or hardware plugged into it. Try removing any CD drives or add in devices.
Good luck
Dec 01, 2008 | Dell Latitude C400 Notebook
Compaq presario 1200-118xl note book problem
Anyone find the answer to this problem yet? I'm having the same problem too..
Feb 06, 2008 | Compaq Presario 1200T and 12XL Series...
Dell Latitude D400 Notebook Logo
88 people viewed this question
Clive
Clive
Alun Cox
