Question about Pyle PLA885 Car Audio Amplifier
Pyle PLA885 amplifier blows 25amp fuse. Ideas?
  • 1 more comment
  • cprv Sep 24, 2009
    Thanks for the reply. The amp is mounted on its side in a Motorhome. It's not touching anything, been there for several years now. Blows the fuse on the amp itself. Cheaper to just replace it for us. We are a RV repair shop.
  • cprv Sep 24, 2009
    Can you tell me if a Pyle PLAD142 will directly replace the old PLA885? Thanks for the help.
    Donn
    Central Point RV
  • David
    David May 11, 2010
    ok what fuse is it blowing then fuse on the remote wire in the fuse box or the one on the amp its self or the one right off the battery under the hood that one is normally about 10 inches away from the battery.....but if you have the prob i had your probably blowing the one on the amp my prob was i had the amp just laying in the trunk and it would move around when i hit bumps or turned it would slide and blow the fuse... i found that this was because when it moved it would hit a bolt in the trunk flooring and ground itself out try mounting the amp so it doesn't move that may be your prob. Good luck
  • 17 Answers
Make sure you have a solid ground sometimes having a loose or not fully good ground will couse this check the following ... is it connected to a semi or fully painted surface .. is the ground cable the right size .. your ground should be the same if not bigger then your power wire with a 8 gd power wire you should use 8 gd ground also make sure your using the right size power wire if your going to small this can happen
Posted on Sep 26, 2009
  • 59 Answers
To much power draw
Common symptoms
1. a short in the power line causing the amps to go haywire, i have seen a short in a 8 guage wire before where the seats had been removed for the installation and when the seats were put back in they caught the wire under the bolt, amp worked fine at low lvls but at higher volume the short caused the fuse to blow, verify there is no shorts,
2. speakers not set in proper configuration for the amp, you may have it setup so that they are at 16ohm or 1ohm and the amp can't handle that ohm specs causing the amp to over load and draw more power.
3. Blown sub, a blown sub can cause it's ohms to go crazy while it's moving causing the amp to overwork itself. however the sub may still sound fine. you can check this by hooking a multimeter up to both posts of the sub set on ohm and push the speaker cone up and down looking for spikes on the ohm meter. ==This is a very common cause of the problem you are describing.==
Posted on Sep 24, 2009
  • JollyRoger00
    JollyRoger00 Sep 28, 2009
    Before you attempt to change the amp, i would test the speakers,
  • 1,068 Answers
Signs of a short, did any wires touch while you where hooking or un hooking the amp? if not then the internal power supply probably has a short in it and needs to be repaired. you can swap the fuse for a good one and hook it back up and make sure you don't touch any wires and if it blows it again then your issues is internal and will need repair if it doesn't and everything seems fine then wires could have touched or the amp was ran past it's limit and blew the fuse to protect it self. good luck and ask any more question you have
Amp keeps blowing internal fuses on a memphis 16-mcd1000
got pyle pta 3000 watts dj power amp when turn on my power light indcatior light dont work but it still runs
Dec 31, 2013 | Car Audio & Video
Blowing fuses
because Pyle... Fuses only blow when the current draw is too high. more than likely you are trying to get too much power from this inferior amp. Thus causing it to distort and damage parts.
Oct 29, 2013 | Pyle PLA2200 Car Audio Amplifier
Looking for a connector for the high level inputs on the PLA885 amplifier
Websites Get Hacked, Backup Data 2GB Free Website Backup In Cloud!
Sep 21, 2011 | Pyle PLA885 Car Audio Amplifier
I need to know how to hook up my pyle pla4278 4 ch 2000watt bridgeable mosfet amplifier
Hi, I assume you are powering regular speakers in the car, right?
The amp needs a power cable from the fuse box or battery.
This cable should be about 6 gage and should have a fuse of about 150 amps.
You will need a ground cable, also 6 gage and connect it tightly to the chassis under the dash.
Disconnect all speaker wires from the head unit, and use a pair of RCA cables to connect the head unit preamp outputs to the amplifier.
Also from the head unit, connect the blue wire to the "turn on" terminal of the amplifier.
Finally, connect your speaker wires to the amplifier.
Your speakers should be rated for at least 500 Watts, or you will blow them with this amp.
Please let me know if you have questions and thanks for using FixYa.
Jan 12, 2011 | Pyle PLA4278 Car Amp
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Power fuse on amplifier blows as soon as the power cable is connected
you should check the fuses your using may be too small and make sure you connect the positive first then the ground cable and there are no shorts when you ground the amp.
the most common will be the fuse ampage is too low thats why its blowing when you power the amp
Sep 18, 2009 | Pyle PLA600 Car Audio Amplifier
My wipers keepr blowing the 25amp fuse. I replaced
check the wire motor power circuit and see if you have a bad wire
Jul 07, 2009 | GMC Sierra 2500 Cars & Trucks
Blowning fuses
i would check the wires going to your headlights there is a wire shorting out somewhere
Jun 13, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Pyle PLA885 Car Audio Amplifier Logo
158 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
