Question about ASUS P5P800-VM Motherboard
Asus P5P800Vm/s motherboard,led status green,whin i switch on powe button ,only cpu fan will just move and again it will stop,
  • 59 Answers
Bad power supply or bad processor, from what ive seen from alot of the asus boards, your processor is shot, but i would try a new power supply just to be sure
Posted on Sep 24, 2009
P5p800vm no power
Your PSU would seem to have failed.
Aug 15, 2013 | PC Chips Computers & Internet
Asus p4u800-x motherboad. When the computer turn on there is long continues beep and the cpu red light does not light up. But the green LED light up.
basically this is your motherboards way of saying its broken and most likely not repairable, however this may also me the motherboard telling you that the ram of cpu fan are not running properly if it's ram replace all modules and try again if its the cpu fan try replacing it with a new fan
Feb 04, 2012 | ASUS Computers & Internet
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but...
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
Feb 03, 2011 | ASUS M4A79XTD EVO Motherboard
In asus P5VDCMX motherboard power led and ide led doesnot glow , but pressing power switch cpu fan run,monitor screen blank.
mybe something wrong with your hardisk or Motherboards.you can sheck with manually open the case and try to reconect and conect again the cable.
Mar 24, 2010 | ASUS Computers & Internet
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
On Asus p5b-mx motherboard no beep no lcd no bios only fans and l
Check your Video Card. Perhaps Bad driver or a malfunction
Dec 11, 2008 | ASUS P5B-VM DO Motherboard
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Asus 945 motherboard is in stand by mode. When I power on , the LED of mother board is glow The cpu fan just jurking and stop. And the LED of motherboard is still now glow.
Hi kausik, that green led you see on the motherboard is just letting you know there is power to the board. (This is normal).
You'r CPU fan jerking & stopping is a bad thing & has nothing to do with standby mode. Your CPU fan needs to be replaced.
There are a bunch of Asus 945 boards, just click the link to see.
http://support.asus.com/download/download.aspx?SLanguage=en-us
If you are able to remove the fan from the heatsink than you may be able to buy a fan from here.
http://www.tigerdirect.com/applications/category/category_tlc.asp?CatId=99&name=Cooling-Products
Most people replace both heat sink & fan.
Have more questions, feel free to ask.
Good Luck!
Mike
Apr 18, 2008 | Intel Motherboard
Asus k8v-mx motherboard
BIOS of your motherboard is crashed. M/B needs to be replaced
Jan 12, 2008 | ASUS K8V-MX Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS P5P800-VM Motherboard Logo
244 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
