Question about Motorola Mobility MOTOZINE ZN5 Cell Phone
Want to replace the front glass on a motorola motozine phone. Can this be done fairly easily? It has a single crack going through it. The lcd display is fine. My insurance deductable is $90 but I can get a replacement glass for about $26.
Monitor of my motozine is broken,how to fix it and wher?
You can find new lcd screens on Ebay.com, they are shipped with the required tools and instructions. But since your screen is broken you may have need to buy a screen glass too, they are shipped together with the cases. The case itself with the glass cost abot 25$ itself, so does the screen, therefore it looks like smth. about 50$ total + the work (if you can't do it yourself).
Feb 13, 2011 | Motorola Mobility MOTOZINE ZN5 Cell Phone
Touchscreen stopped working
HERE'S A LINK TO REPLACEMENT SCREEN... http://www.cellulardr.com/motorola-cliq-xt-mb501-faceplate-with-touch-screen-digitizer-and-lower-navigation-keypad-assembly-with-flex-cable-tmobile-quench-front-housing-frame-with-touchscreen-lens-glass.html?cat=248
THIS IS THE SITE: THERE ARE TWO DIFFERENT SSCREENS, ONE WITH THE WHOLE FRONT PANEL FOR $100.00 AND ANOTHER WITH JUST THE SCREEN PART FOR $89.00 YOU CAN CALL: Call 818-553-2700 OR HERE'S THE LINK: http://www.cellulardr.com/motorola-mb501-cliq-xt-main-lcd-display-screen-with-flex-cable-tmobile-quench-main-lcd-display-module-with-flex-cable.html
Dec 17, 2010 | Motorola Mobility CLIQ Cell Phone
Screen cracked and turned black, unable to use desk top the glass that you touch on top of the lcd screen is not cracked,its the bit underneath.
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Oct 31, 2009 | Motorola Mobility A1000 Cellular Phone
My razr 3c has a broken front glass the lcd is still working . I just need to get the glass replaced?
Hello
You can get the front lcd glass at motorola service center, or you can visit in this site for more info about motorola accessories motorola glass i hope you enjoy this site...
Angel
Thanks...
Jul 31, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Nokia 6288 Broken front screen and LCD
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Dec 18, 2008 | Nokia 6288 Cellular Phone
Cracked screen can it be fixed
No..the Glass Display Panel ... If cracked... Cannot be repaired.. it is not just a piece of glass, it is a layered panel with pixel grid panels along the top and sides that show color to the grid on the screen panel and go all throughout the display ..
If the Crack ocured behind the display panel on the plexiglass protective panel, that can be replaced... but No Not The Front LCD Display Panel.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Motorola V3xx Razr Front LCD Screen Glass Repair
Your best bet would be to take it to your cellphone company and have them fix it for you.
Jul 03, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola v3x white screen help
get the new display for ur cell and fit it ... or try to remove the current display and reconnect it ... if it doesnt works then u buy new display ... no need to change the cell...
may it may charge aroung 200 -300 rs thats all.... just go 4 it...
Feb 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Broken screen plz help
you mosst be kiding with you speling or how old are you ..nothing that you can do but go to the cell phone store they have damage unit to use as yonk and for a few dollars they will help you...good luck
Jul 26, 2006 | Motorola Mobility A630
Motorola Mobility MOTOZINE ZN5 Cell Phone Logo
191 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
