Toshiba satellite wont connect to internet. Wireless network adapter showing vista error code 31. Any ideas
    President:
  • 1,015 Answers
Try removing the wireless adapter in the device manager and then re-boot computer. Vista should detect the adapter and re-install the drivers. if that does not work you might want to download the latest drivers and software from Toshiba and install them. Another thing you can try is to use windows restore to return the computer to a time when the wirless adapter was working.
Posted on Sep 24, 2009
Testimonial: "Thanks a lot for your help. It seems to be working now."
Toshiba satellite 5005 s507 no wireless?
Use network to setup a wireless connection. You must have a RJ45 hard line for internet to perform this task.
Jan 20, 2013 | Toshiba Satellite 5005-S507 Laptop...
I have a Toshiba Satellite L305D-S5934 notebook with Windows Vista Home Premium. I use Verizon wireless broadband to access the Internet. I can connect to the internet using their USB modems just fine, but...
You didnt mention via cord(Lan Cable)have you ever used it? is it works?
Ok let assumed the cord can access the internet.
1.Enter your device manager
2.locate Network Adapter >> there should be 2 or 3 network adapter type
3.If you found any question mark with yellow colour >> right click on it >>> update driver
4.toshiba has application built in called zero configuration >>> open it, and try setting something matched with are you looking for ( sometimes the program stuck on something else network adapter eg. LAN cord or built in Wifi
akee_akee@live.com
Aug 17, 2011 | Toshiba Satellite A135-S4487 Notebook
Isatap adapter????error code 31,cant get onto internet,wont find my router or any other devices,really stuck on this one?
Use System Restore to revert device drivers and registry configurations back to a state previous to the Code 31 error. Be sure to choose a restore point from a date and time before you know or suspect that the Code 31 error first appeared. 8. Disable any hardware-based security on the device.
for more help visit CBR Tech Solutions
Jan 22, 2010 | HP Computers & Internet
Network Driver Issue/Internet Connection issue
you can try a couple of things, on the back of the router is a small reset button, you will need a pen or pencil to push this button, hold it in for 10 sec. or so, until the router resets, and try to connect then, or unplug router, leave off for 10-15 sec. plug back in and wait fir it to reset this way, or a more involved way is to go to your DOS or command prompt window, type in this as follows
ipconfig /release
(wait a few seconds for this to do its thing)
ipconfig /renew
(if this doesnt work ask your parents if they put a block on the router)
Dec 30, 2009 | Toshiba Satellite A205-S5812 Notebook
Cannot connect to wireless
Hi, reinstall the latest adapter drives.
Aug 01, 2009 | Computers & Internet
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
Internet connection shows good bars but can't connect to web
first, can you please tell me if what OS are you using?
: if its VISTA or XP, please remove the network profile in your laptop ...
then search again for the network ... by the way what router are you using ? if its linksys please update this thread so that i can assist you if there is a need to reconfigure.
goodluck
Nov 25, 2008 | Linksys WUSB100 Wireless Adapter
Vista Premium wireless network callapse
Go into device manager, under control panel, go into network adapters, select your wireless adapter, right click on it, click uninstall, if you're with vista, it'll prompt you to delete the drivers, just leave that box unchecked then click ok. After the adapter is gone, click on action on device manager then click scan for hardware changes. The wifi adapter should be re installed. after you check that the wifi adapter is back on the list, you can exit device manager. Click start, connect to, try to reconnect to your router and it should work fine. After you have established internet connection and you can browse, you can download tthe Skype program again.
Hope this helps
Sep 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite limitations on network adapters all wireless, need other
you need to log into the router setting by typing something like 192.168.*.* etc,check the right one for your router and enable some type of encryption like 128bits wep..Then your network is secured with a password which will stop anyone access.Now also change your router password if possible to prevent access from others...Hope this helps.
Sep 06, 2008 | Toshiba Satellite M40-S417TD Notebook
Wireless does not show up in Network Connections
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
