Question about Philips 19PS50S 19" TV
The tv does not respond to some buttons on the remote but does to others. The ones not working are Power and Channel but Volume and Mute work. New batteries make no difference.It is a Phillips tv with original remote. It worked at night and then the next day there was this problem with nothing happening in between.
  • 687 Answers
Try these three generic codes for a Philips TV with a Sky Remote;
0584
0065
0266
PRESS
TV,
RED + SELECT ( blinks twice)
TV,
<try one of the codes above>
TV,
SELECT
At least one should give you volume and turn OFF/ON funcitonality.
LOL
Posted on Oct 04, 2009
  • 325 Answers
There is a way that you can check the remote buttons are working.
Get a mobile phone with a camera on it.
Set the phone to camera mode.
Whilest looking through the mobile. point the the Tv remote at the camera phone and press each button individually. what you will see on your mobile is a light coming from the remote for the buttons that are working. If certain button are not working you will see no light through the camera phone. If this is the case you may need to get a replacement remote.
If you do need to replace the remote this can be quite expensive to buy from the manufactor. So what I would surgest is getting a sky remote off a friend or family member. or even Tesco. argos. It does not matter what the remote is ie Standard, Sky+ or HD remote. (which ever you can get cheaper) The reason behind this is Sky remote have a default code in them to work PHILIPS tv's. When you get this remote if it does not work your telly straight away. What I would then do is remove the battery's from the remote for a minimum of 10 minutes that way it loses the code someone has set it up for and defaults back to Philips Code.
All of the above will sort your Problem out.
Thanks Little Dish Fitter
You owe me a Pint. : )
Posted on Sep 24, 2009
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Tv not responding to remote or buttons on tv
Well okay!
couple of questions?
1) Is a multi remote - does it or can it control other components like a DVD player or a VHS or Cable box?
2) If it does - you may have selected one of these other components to control
NOTE: Try depressing the TV button and then try the other buttons such as channel or volume to see if it's back working.
Blessings,
A/V Guy
Nov 19, 2009 | Element Electronics FLX-2210 22 in. LCD...
Toshiba 32A61 will not respond to the original remote or the cable remote (volume, channel or power). TV works fine if buttons on the set are used.
Check the obvious.One easy way to know if your remote is working is by watching the diode in the front of the remote through a digital camera (from a cell phone or any other). If you see a light beam emitted, then the remote is working and the problem is most likely in the TV.
Aug 25, 2009 | Toshiba 36A40 36" TV
Konka tv code
Try "auto search" with your remote. Normally you press the TV button and the "OK/Select" button simultaneously for about 3 seconds untill the TV light burns steady. Then press "channel up" one press at a time untill the TV turns off. When it turns off, then press "power" on your remote and if the TV comes back on, test the other functions such as volume and mute. If all functions work, then press the "TV" button one more time to save the code and then you are "in business". If functions do not work, then continue to press "channel up" untill the TV shuts off a second time. Then press "power" and test all functions. Continue repeating this until you find a code that enables all desired functions. Hope this helps.
Keever
Mar 04, 2008 | Televison & Video
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Menu wont work, continuos channel search
Usually, this means that something has spilled into the front of the set and has contaminated the pushbuttons. If one of the channel pushbuttons has fluid in it, the set will just sit there searching for channels and will not respond to any other commands. The computer thinks you are pushing the channel button and responds accordingly. When you push another button the computer does nothing because it thinks that you are pressing 2 buttons at the same time. The board should be cleaned and any contaminated pushbuttons replaced by a qualified tech.
Aug 23, 2007 | RCA F36715 36" TV
Philips 19PS50S 19" TV Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
