Question about Refrigerators
MY SIDE BY SIDE REFRIG IS NOT COOLING ,THE FREEZER WORKS GREAT BUT THE REFRIG ISNOT COLD WHATS THE PROBLEM. THANKS JOSIE
  • 27 Answers
Check to see if fan in freezer is blowing... if not then that's most likely your problem... air passage to refrig side may be blocked if it is blowing
Posted on Sep 24, 2009
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Freezer cools great other side does not
the damper vent door between the refrige and freezer is not opening and letting in cold air from the freezer,they freeze up or the cold control isnt working to control the damper door
Mar 31, 2010 | Whirlpool Refrigerators
ED25PQDW01 side by side refrig -freezer is inconsistent. Need to have full cold to maintain freezer temp. cleaned coils, but still an issue.
Do you see a light coat of frost in freezer section about 12 inches up (defrost problem indication) ? Has the icemaker slowed down a bit in ice production ? What is the refrigerator control set on ? When you turn the freezer up completely , it cuts off the cold air flow which cools the refrig section . If refrig control is set mid way , turn it up higher , so refrig will run longer , but lower the freezer setting so some cold air will enter the refrig section . Also check to see if the freezer fan is working .
Aug 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Freezer stays cold but refrig does not
Hi, Look and see if there is frost built up in the freezer on the back wall.
If there is frost, it will not let air circulate properly and it means there is a problem in you self defrosting cycle.
Please let me know if this is what you find so that I can assist you further.
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Re: Refrigator will not stay cold
defrost problems are caused by 3 things
bad: 1) defrost timer/ timer board 2) defrost heater (in freezer) or burnt wire going to the heater 3) bi-metal thermostat (round metal piece attached to the coils with     at least 2 wires going to it)
a good technician can test components without the machine running. all you need is a simple $5 meter any tech that gets angry, show him/her the door!
Jun 15, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
