Question about RIM BlackBerry Storm 9530 Smartphone
Some of the touch screen keys are not responding, can't dial 2, 5, 8, or 0
  • brownv18 Sep 24, 2009
    What do I need to do about the problem? I don't see my phone type listed. Blackberry Storm 9530
Tablet is not responding ,to any comands
Touch Screen Not Working Android Problem [Fix] - TechKhoji
www.techkhoji.com > Android
Feb 27, 2014 - How can I reboot my tablet, the touchscreen is not working. ....Sometimes when I turn on the screen it doesn't respond to my fingers. Then I ...
Android Tablet Touch Screen Problem Solution - YouTube
? 21:36
https://www.youtube.com/watch?v=h7_aqvkfKL4
Jun 16, 2014 - Uploaded by SOLOMON BOTCHWAY
I CANT Believe it, i Actually fixed my tablet.. all i did disconnect the ... my touch is working how to fix the screen not showing? ....2 WAYS TO FIX IPAD TOUCHSCREEN NOT RESPONDING - WORKING - Duration: 5:17.
Samsung galaxy Tab S 10.5 not responding by touch ...
? 2:54
https://www.youtube.com/watch?v=XkK9zCx46gs
Jul 7, 2014 - Uploaded by Linkhunter
i just the new tablet by samsung i recharge the tablet after that isnot responding by touch and so Sim card do ...
Touch Screen Not Responding ' DaniWeb - DaniWeb IT Discussion ...
www.daniweb.com > ... > Hardware > Mobile and Wearables
Jan 11, 2016 | Tablets & eReaders
Zte n910 is locked need to hard reset for zte n910
Warning Hard Reset will erase everything on your Device !
You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
1. From the Home screen, press the Menu Key and touch Settings.
2 Touch the Privacy
4 Touch Factory data reset.
5 Touch Reset phone.
6 Touch Erase everything.
Apr 16, 2014 | Clear Screen Protector - ZTE Anthem 4G...
Samsung star touch screen mobile GT-S5233 touch screen is not responding pls guide me to resolve this issue.
Jul 13, 2010 | Cell Phones
The touch-screen of my phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the lasr dialed or received. Even the accept / reject...
The touch-screen of my china phone is not working. The four keys on the bottom are working. I can receive calls thru on key but can not dial a number except the last dialed or received.
Jun 29, 2010 | HTC Touch Diamond Smartphone
The touch screen is not responding to any of the touches and it started as if the screen alignment was not correct like if you want to dial a number and you are pressing 8 it will write 2 but now it is nor...
i have a nokia x3-02 the touch screen seems to be out by approx 1/2 inch i.e. pressing messages gets camera, due to this fault i cannot alliange it , can suggestions
Jun 29, 2010 | Cell Phones
How do you set and delete speed dials on minolta 2800 fax
Speed Dial Keys
The fax number and other data for a particular destination can be programmed using a 3-
digit Speed Dial Number. This feature allows you to transmit a document to the
particular destination by pressing the Speed Dial Key, entering the 3-digit number and
pressing the START Key. You can program a fax number in any of the 100 Speed Dial
locations, number 001 to 100.
Entering
1 Press the PROGRAM Key and scroll through the
menus until you reach the DIAL REGISTRATION
Menu. Press YES to begin programming.
2 Press 2 or scroll down to the Speed Dial menu and
press YES.
3 Enter the number of the location you want to
program and press YES.
4 Enter the Telephone number you wish to transmit
to and press YES after checking to see its OK. If
you want to enter the sub-address, press the Down
Arrow Key.
5 You can press sub-address up to 10-digit.
REGISTERED! KEEP?
OK=YES (EDIT/DEL=NO)
EDIT *DELETE
-SELECT&PUSH”YES”-
DIAL REGISTRATION?
YES / or 1-6
2 SPEED DIAL?
OK=YES
SPEED DIAL =_
OK=YES
OK=YES (SUB= )
SUB=_
OK=YES
Edit/Deleting
1 If you wish to change any entry, a screen allows you to accept or change.
2 If you wish to change a Key that was previously
programmed, this message appears. Press YES to
keep this location as is, or NO if you wish to edit it.
3 If you choose NO, use the arrow keys to select
either EDIT or DELETE and then proceed with the
needed changes.
Group Dial Keys
Instead of their regular functions, any of the One-Touch Keys can be used as Group Dial
Keys. Destinations already stored for One-Touch, Speed Dial can be entered in a Group
Dial Key. Each Group can contain up to 50 locations.
Entering
2 Press 3 or scroll down to the Group Dial menu and
press YES.
3 Press the One-Touch Key you wish to use.
4 Press YES to accept your selection.
NAME=_
OK=YES
REGISTERED! KEEP?
EDIT *DELETE
-SELECT&PUSH”YES”-
Nov 28, 2009 | Minolta MF1600E Plain Paper Laser Fax
My screen does not respond to my touch
You need to Calibrate the touch screen.1Turn off the Nuvi. 2 Turn on the Nuvi and hold the Power key to the left for about 30 seconds untill the calibration screen appears (white screen with "Press dot")
Nov 08, 2009 | Garmin nuvi 255W GPS Receiver
Touch screen do not respond
could you explain in detail what s happening with your phone??
u said that ur phone cannot be unlocked...but then u say that it happens typically during nights...do u mind elaborating?
May 10, 2008 | HTC P3300 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
306 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
