Question about HP LaserJet 1320 Printer
How do I replace fuser on an HP Laserjet 1320?
  • 88 Answers
Call hp they will walk you thro it or go online and do instant messanger tech support chat on the hp website
Posted on Sep 24, 2009
SOURCE: HP LaserJet 1320 lights
hi there andy u will find your harraness from u formatter board has beeb broken or one of the plugs arnt making contact on the baord only to solve the problem is to trace everypoint out to find the break and then replace that cable link
Posted on Dec 07, 2007
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
jeffdynamics
  • 18 Answers
SOURCE: HP LaserJet 3030 Fuser Rollers
fuser roller is part of fuser assimble so you need to do is removed first fuser assy set aside and replaced the roller..tnx
Posted on Apr 14, 2008
SOURCE: 50.1 fuser error on HP 8150 LaserJet Printer
You have problem with the Low Voltage Power Supply
Posted on May 30, 2008
  • 102 Answers
SOURCE: hp laserjet 1320 printing blank pages
Hi, If you have replaced the toner acrtridge and still the printer is printing blank pages than it please make sure you have removed the maler strip of the toner cartridge if yes than perform engine test page of the printer wherein remove the side panel and there is a small button to press and it print engine test page and that will bypass the formatter if the engine test page is also blanik than it is the issue with transfer roller (Which create the image) Power Supply( Create image on transfer roller) or Laser/Scanner assmbly which creates the laser image on transfer and all these three parts are not customer replacable(Hardware Issue) and customer need to get the printer repaired by HP Authorised Engineer.
Posted on Jul 01, 2009
I have a HP 1320 printer that doesn't fuse properly on the first few pages. After a few pages it is okay. I have replaced the fuser unit already, it did not change. Thanks
That suggests to me that a temp sensor is faulty. It's allowing print jobs before the fuser has reached the proper temperature.
Aug 08, 2013 | HP LaserJet 1320 Printer
When i trunn on and when i want print all ways stuck
if you see brown marks on the center top of your page then its your feed roller... hp feed rollers come out easy... Get some rubbing alcohol or hand sanitizer solution and clean with a paper towel... Make sure to dry your feed rollers then put them back in... that should clear up your issue... if that still does not work you may need to replace feed rollers
HP LASERJET 1320 FEED ROLLERS TRAY 2
If it feeds ok but gets stuck at the back then chances are your fuser is bad. The belt is most likely ripped.
HP LASERJET 1320 FUSER ASSEMBLY
Sep 12, 2012 | HPLASERJET1320N LASER Printer INTEGRATED...
The fuser film of hp laserJet 1320 printer is Tear and i want replace it
The Same thing happened to my
HP Laserjet Pro M1536DNF and I am also hoping for a solution soon. I even returned one of my previous HP printers because it was just a pain!
Apr 25, 2011 | HP LaserJet 1320 Printer
What is the mathod of replace heater fuser film hp 1320 printer
You need to unzip the printer to replace the fuser film.
Mar 06, 2011 | HP LaserJet 1320 Printer
check your fuser assembly
Mar 09, 2010 | HP LaserJet 1320 Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
My HP 1320 is crinkling every page. I've cleaned everything, changed the toner cartridge, but still have the problem. Ideas?
If the crinkle is a fanning or accordion, it is time for you to replace the Fuser.
This is almost always the reason.
Other then that, small pieces of paper can be stuck in the printing path, often behind the fuser.
Removing the back cover, and then the fuser is the best choice.
Your User Manual provided with the device shall explain how to remove the fuser, though it is relatively simple with limited tools.
Apr 14, 2009 | HP LaserJet 1320 Printer
Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
Feb 27, 2009 | HP LaserJet 1320 Printer
Paper Jam HP LaserJet 1320
hi,
try to check the maintenance kit of you printer, the possible cause of that are the two main parts of fuser assembly one is the upper roller which is the fixing assembly w/ fuser sleeve try to look at it if it has a silicon paste, if not apply a silicon. the other one is the lower roller which is the pressure roller. check it if you think that it's soo soft rather than the original you need to replace it..
when you done that things your unit is good condition again..
thanks,
rey
Nov 05, 2008 | HP LaserJet 1320 Printer
Printing fent text
have you try to replace the toner ?
could be that or your fuser or dust in the laser assembly.
Jan 16, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1320 Printer Logo
1,360 people viewed this question
Seeker5211
Seeker5211
