Question about Mtd FASTATTACH MANUAL SLEEVE HITCH
Won't start it feels like it maybe in more than one gear won't shift back fist gear
Wont shift out of first gear code P0882
Lotta times its the solenoid. Automatics are so complex ...cud b many dependin on age. Accumalator valve is anothr. Gettn a trans flushd is often a kiler. A tv cable ajust also. Get a good testdriver at surecritic.com
Jul 06, 2015 | 2006 Chrysler PT Cruiser
Chevy cavalier wont shift into third gear
shift solenoid for third gear maybe bad up inside the transmission pan
Mar 02, 2013 | 1998 Chevrolet Cavalier
Suzuki won"t shift into gear unless I turn the car off and put it into first
make your adjustment to clutch, see how that works, but start saving up for a new clutch, or just have your inspection mechanic, take a look @ it for you, make the adjustment, and he can remove a cover and inspect the condition of your clutch with his own eyes. its a lot easyier for him than you. then, you'll know for sure. good luck
Jan 13, 2013 | 2001 Suzuki Grand Vitara
Gear shift feels like a pin fell out. Seems to be flopping around. Won't engage in any gear.
Look at the tube the shifter goes into, is there a pin in a hole there? If not find it and reinstall the pin that retains the shift arm to the steering column barrel.
Oct 09, 2012 | Cars & Trucks
88 ford f150 gear shift lock
A common cause when the gear is on the steering column is a worn out pin. That pin holds the lever to the shift assembly. Try removing the gear shift lever and examine it.
  • If the bushing between the pin and the shift is worn out, replace it.
  • Examine the tip of the the gearshift and replace the shift if it's worn out.
Hope I've helped. If not please feel free to contact me with more details.
Nov 20, 2011 | Nissan Cars & Trucks
Put a new transmission in and now the car from 0 to 30 has a slow start. but after that it pulls like its suppose to.
Try putting the transmission in low or 1st gear manually shift it down and try taking off as you accelerate shift it manually to 2 then drive. Did it take off like it should when you put it into low and then shift up or did you feel more power when it was in low if so it sounds like the transmission is not going into low gear but taking off in maybe second gear or even drive. When it takes off in any other gear but low it will start slow and sluggish and as you begain to gain speed it will start feel normal but thats because the speed matches the gear you in at that point.If my assistance was helpful please take the time to rate my assistance thank you.
Mar 01, 2010 | 1995 Buick Riviera
Cannot get into any gear
check make sure the clutch master cylinder working properly along with slave cylinder. both master and slave don't have to leak fluid to be faulty, the rubber seal inside the unit could be worned and when apply pressure the fluid blow by or seep between the rubber seal causing the the unit not to work properly giving you a weak feel and pressure at the pedal. both unit have to work properly in sync. if one are weak you will have the same issue. clutch should have a good tight feel not sloppy or weak. pressure plate will also play important role, weak pressure plate will also give you a weak pressure feedback from the foot pedal and also will cause the synchronizer in the transmission not to engage and work properly. check this basic item fist before messing with your tranny. clutch master and slave cyc are fairly cheap to fix and replace.
May 10, 2009 | 1993 Jeep Wrangler
V-rod gear shifter won''t click back up
sounds as though your gear lever return spring has broken and will need replaceing
Dec 27, 2008 | 2004 Harley Davidson VRSCB V-Rod
Mtd FASTATTACH MANUAL SLEEVE HITCH Logo
95 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
