Question about Ricoh 3310LE Plain Paper Laser Fax
REMOVE ACCESS CODE
Recently we added a code to restrict users from making copiers on our fax machine. Just wanted to know how to remove it so that copies can be made on the machine again. Thanks.
  • Ricoh Master
  • 1,297 Answers
Enter in the user tools and select the password cancel or machine settings and set the machine.
Posted on Sep 27, 2009
The error code appearing on our bizhub250 is c2557
. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Jun 11, 2015 | Konica Minolta 250 Bizhub Copier Fax...
What is "enter access code for third party devise on Oliveti MF25
The access or management password (both 4 digit) refer to the fax section and restricted access.
To turn off you need to enter the registered management password and turn restricted access off. See the fax section of the manual for more information.
Jul 11, 2014 | Office Equipment & Supplies
I have a new nokia x2 phone, when ever i want to swich it on it asks for restriction code which i dont know.
I think its locked with a particular network.You need to enter the restriction code and make it access other networks.You can approach Theunlockspot.com and specify the country,locked network.Based on the availability you can get the unlock(restriction) code along with free instructions.This way you can remove the network lock on your Nokia X2 permanently.
Oct 27, 2013 | Rolling Code Scrambler
I want know restrication code for c3 mobile
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Aug 01, 2011 | AT&T Cell Phones
Cannot use the fax portion of the copier due to password issues.
There is on department code to control the access of the MFP. For fax function, need to make sure the fax board is installed where ( with RJ11 phone port ) the fax board is an optional accessories.
Mar 30, 2010 | Toshiba e-Studio 350 Copier
Always asking for an access code.
You will probably need a technician to set the machine back to it's factory defaults. Sorry
Jun 11, 2009 | Pitney Bowes 9920 Plain Paper Fax
I need to put in access number to fax
Key in fax number press PAUSE twice then access code then start.
Sep 05, 2008 | Brother FAX-575 Plain Paper Thermal
Faxing Long Distance
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Fax
An access code is normally set up by a person or company to prevent long distance faxes or phone calls by unauthorized users. The access code is a series of numbers to access long distance service. Check with your employer for the long distance code or check with you carrier to make sure that this service has not been put on your line by mistake.
Oct 08, 2007 | Brother IntelliFax-2820 Laser Fax
Ricoh 3310LE Plain Paper Laser Fax Logo
474 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
